Sadly, neither can we, without more information.- When does it rattle, only on bumps or all the time.- Does it sound like metal on metal.- Are there passengers in the car when it rattles.Check your seat belt buckle against the pillar of the car, it could be the passengers seat belt when it is not in use.
Quote from: Phil aka 84 on February 05, 2013, 03:08:48Sadly, neither can we, without more information.- When does it rattle, only on bumps or all the time.- Does it sound like metal on metal.- Are there passengers in the car when it rattles.Check your seat belt buckle against the pillar of the car, it could be the passengers seat belt when it is not in use. thanks, I wasn't expecting help. Was going to bring it up at the service on Thursday. It's constant, particularly at lower speeds (60kms and under on flat roads) and loud enough to be really annoying. It sounds like plastic on plastic. I've checked the glovebox to make sure nothing is in there, checked the passenger side door, nothing in there either, made sure nothing was rattling in the middle console area or under the radio where those compartments for stuff are. Doesn't seem to be anything in any of those that could be the problem. It sounds like it's coming from the passenger side though.It happens when I'm alone in the car. Husband hasn't noticed it (but I drive it more than he does) and the one time I remembered to get him to I coudn't hear it for some reason
Quote from: panda on February 05, 2013, 04:30:03Quote from: Phil aka 84 on February 05, 2013, 03:08:48Sadly, neither can we, without more information.- When does it rattle, only on bumps or all the time.- Does it sound like metal on metal.- Are there passengers in the car when it rattles.Check your seat belt buckle against the pillar of the car, it could be the passengers seat belt when it is not in use. thanks, I wasn't expecting help. Was going to bring it up at the service on Thursday. It's constant, particularly at lower speeds (60kms and under on flat roads) and loud enough to be really annoying. It sounds like plastic on plastic. I've checked the glovebox to make sure nothing is in there, checked the passenger side door, nothing in there either, made sure nothing was rattling in the middle console area or under the radio where those compartments for stuff are. Doesn't seem to be anything in any of those that could be the problem. It sounds like it's coming from the passenger side though.It happens when I'm alone in the car. Husband hasn't noticed it (but I drive it more than he does) and the one time I remembered to get him to I coudn't hear it for some reason The seat belt buckle is a serial offender although I thought they had applied a "fix" to that problem in the new model. Of course, if that's it, it won't be evident when the seat belt is done up.
I mentioned the rattles in my FD when I got the brake switch done....Basically got my head snapped off and told that 'rattles' (under the drivers dash and the traditional glove box rattle)were only covered for the first 1500k.....
Isn't that what 20+ stereo volume is for?
Quote from: Gonz on February 06, 2013, 09:00:34Isn't that what 20+ stereo volume is for? So long as it's not 23, 29, 31.
Quote from: Gonz on February 06, 2013, 09:00:34Isn't that what 20+ stereo volume is for? I like to save that for when the wife is in the car
Quote from: ouri30 on February 06, 2013, 09:25:21Quote from: Gonz on February 06, 2013, 09:00:34Isn't that what 20+ stereo volume is for? So long as it's not 23, 29, 31. We're not OCD...much
