Well i can suggest that you change turbo..On my 1.6 liter crdi i'm planing for Intercooler upgrade (just ordered it at tuesday ), and to change turbine. I already have one from 2.0 liter Tucson. It's also VGT so it should work like a charm - we will see. I already did ChipTuning (115hp->136hp / 255nm->306nm), and we are looking if we can get SMT6 or some other standalone or piggyback system to replace the simple ChipTuning.I will stick with 16" rims, but front brakes will be upgraded to 300 mm disks and i'm looking to put on brake calipers from New Santa Fe . This should be some kick ass braking power My service guy is manufacturing on his own LSD - well it's LSD insert but it works like a charm I had it on my Elantra 1.6 L petrol
Hi Guys ,I think Razzy may have Whitline mixed up with Selbys as here at whitline we do not make custom swaybars and have not designed a swaybar for the I30.Selbys were in the old Whiteline building and did custom swaybars so maybe he had one made there but they closed shop about a month and a half ago.Sorry for the mix up that might have been made but to save your phone calls or emails with dissapointment i thought we would clear up on here that we do not have swaybars for the I30 at this stage and have no design coming in the near future sorry.
Quote from: andrejs on April 24, 2010, 07:50:34Well i can suggest that you change turbo..On my 1.6 liter crdi i'm planing for Intercooler upgrade (just ordered it at tuesday ), and to change turbine. I already have one from 2.0 liter Tucson. It's also VGT so it should work like a charm - we will see. I already did ChipTuning (115hp->136hp / 255nm->306nm), and we are looking if we can get SMT6 or some other standalone or piggyback system to replace the simple ChipTuning.I will stick with 16" rims, but front brakes will be upgraded to 300 mm disks and i'm looking to put on brake calipers from New Santa Fe . This should be some kick ass braking power My service guy is manufacturing on his own LSD - well it's LSD insert but it works like a charm I had it on my Elantra 1.6 L petrol Sounds good m8, i would expect they would use a larger Turbo in the 2.0 as would need to to compress enough air to meet slightly larger displacement, but if you put it on the 1.6 i think you will loose some low end grunt, i love low end grunt and think the 1.6 has reasonable low end but i would like more low end and not more top end, i'm happy with top end as it is, as here in Australia we drive like old women ha ha, we think we drive fast but we don't as too many limitations in our speed laws.do you think it will feel like a two stroke? like dead at very low revs then come on with a rush of Torque when the turbo starts to work eficently?also nice to meet youcheers
Hi everybody, In regards to the strut bars:I bought this:http://cgi.ebay.com.au/Hyundai-i30-Blue-Line-Front-Upper-Strut-bar-/260590327282?pt=Motors_Car_Truck_Parts_Accessories&hash=item3cac64d5f2
Hey Lakes,I LOOOVE my car now, IT HANDLES BETTER.i CANNOT BELIEVE WHAT A DIFFERENCE A STRUT BAR MAKES, i'M TALKING ABOUT WHEN CORNERING A BIT FASTER, BUT ALSO JUST FOR REGULAR DIP, DRIVEWAYS, ROUNDABOUTS, POTHOLES HUMPING.It does not shake or tilt or twists around corners nowhere near as much as before.I'd imagine if I lowered the car, gotten kings springs and shockers, better tires it would smoke, however I use this thing for training people and not for racing.In other words it makes the car more rigid which is good for everything including response around corners.For $100 including delivery, this thing is worth it.
