Short life of glow plugs
Guest · 66 · 33936
Offline Rob NZ
    • nz New Zealand
      Wellington
Well, everything went well.
I've since learned that the best way to test glow plugs is to measure their resistance rather than check the voltage drop. Their resistance (measured using the lowest ohm setting on your multi-meter) should be around 0.7 ohms. You can do this in situ after you have removed the metal strap that connects the glow plugs.
The really revealing issue for me was how much the prices vary between suppliers. The NZ Hyundai dealers were the most expensive. Seekpart24.com had a good range of prices from different suppliers. The cheapest I found was through eBay from a seller called seoulparts. I had 100% satisfaction. Price was NZ$49 for 4 NGK Y527J glow plugs free postage! (NZ$12 each). Delivery from Korea to NZ was about 9 days.
Car is now starting sweetly. All ok. I do recommend you use a torque wrench to tighten the plugs they are only tightened to 15 Nm (quite light handed in other words).
Cheers,
RobNZ
  • I30 1.6 CRDi Elite
Thanks Rob, very useful info there :D
Offline ElleB
  • Our Elle B
Good News Rob....and a really helpful post, especially with the "sourcing info".  :goodjob2:
I will add them into my i30 tips and suppliers file. :snigger:
Hopeully I will not need them, but at that price, one could almost have 4 set asid, just in case !!! :winker:
I wonder if the resistance drops gradually as they get closer to their giving up the ghost? Thus one could see that there could be an issue soon.. :confused:
  Tony
  • 2016 i30 CW auto
Offline Tullybanana1
  • Tullybanana1
      Victoria
  • Mmm....Turbo's...
I know I'm a little late but we just had the Glow Plugs replaced under warranty (just) in my partners 2008 model, (I posted in this thread way back).
I left it til very late in the warranty period because i hate the dealership touching our cars, I've found dealerships to be very hit and miss, also i thought the later the better because now the Glow Plugs are new at the end of the warranty period.
Anyway, the problem is solved and we only have to let the "Glow Light" glow once before starting instead of 3 or 4 times beforehand.
I also left it late because I'd diagnosed the problem a while back and knew for sure the problem was the Glow Plugs.
We have 2 diesel i30's and the other one has never had a problem and surprisingly the dealership said they'd never replaced Glow Plugs before.
Bye for now....
  • Hyunda FD i30 x 2 / Toyota Mr2 turbo / Toyota Corolla 4wd / Nissan Condor truck
Cheers TB, don't be a stranger..  :whistler:
