Hi. Hoping someone can answer an issue that just started happening tonight. I noticed a small squeal while driving. Barely noticeable. Then just around the corner from home it seriously started grinding.
Drove it the last couple of hundred metres home and put the front end up. Spinning the 'problem' wheel I felt it grinding. I then put the other side up to feel the difference. It was very similar. Went back to the original wheel and it doesn't seem to wobble left to right. Instead the noise seems to be coming from the engine side of the shaft. Anyone had this issue?
Any help would be appreciated.
