The lights are really easy to change. You will need 4 globes in total. So yes 2 of what I linked to eBay.
If you also wish to change the centre interior globe. You only need 1 globe. Here is the link to eBay as well
4pcs Canbus 31mm Festoon 6SMD 5630 LED Car Interior Dome Map Light Bulb Globe | eBayThe rear licence plate holders just clip out with a flat screwdriver. Then the globe holder just twists from that. Pull out the globe & fit in the LED globe.
LED globes will only work one way. As there is a positive & negative side. So just make sure you check that they are working before clipping them back in.
With the interior lights. I uses a small flat screwdriver on the inside edge to unclip the cover. Then pull out globe & slot the new LED in.
I wanted to make sure NO overspray got anywhere on the car. Plus for only a couple of bucks for cheap plastic drop sheets.
I would also like to do something about the chrome trim around the front grill. But I would rather use some sort of vinyl wrap rather than paint.
Would be a bit more long lasting I think.. Still waiting on the cabling kit to arrive. So I can start work on the stereo.
I'm going to get all the amps wired up & installed before I start on installing the front speakers.. So than at least I'v still got radio in the car..
