Hyundai i30 aftermarket wheels
Offline giwrgos_p
    • gr Greece
Hi, I want to put in my i30 wheels but the Hyundai wheels is very very expensive, and decide to bought aftermarket. I want to take 16" but I don't know which is the right ET AND J.
I found these wheels :link: CERCHI IN LEGA X5B 7x16 ET 45 OZ HYUNDAI I30 5x114,30 MATT GRAPHITE DIAMOND 50E | eBay
Please if anyone knows to give a solution. Sorry about my bad English. Thank you
* My model is after 2012
  • 2015 Hyundai i30 1.4 CRDI
I think you'll be right with that size but I would highly recommend you to call through a local tyre/wheel service centre and get them to check the correct sizing.
Nothing wrong with 16's and the GD models will fit 18's though the offset is what is critical.
Offline giwrgos_p
    • gr Greece
I read in the forum someone suggest the offset to be 50. Also what types is ideal for 16"?
The size is correct but the FD 16" offset is 50P (positive). The FD is the original shape, not sure if yours is that or the updated shape.
The 15" is 47P and the 17" is 56P
Offline giwrgos_p
    • gr Greece
So the wheels of link which have 45 isn't right? Which is the minimum and maximum offset can I put?
Just to explain a bit. The offset can be negative, positive or zero.
Positive is what is found on most front wheel drive cars. In this case the hub mounting surface (where the wheel bolts up to), is towards the outside of the wheel. So, effectively more of the rim and tyre are towards the centre line of the car. The offset is a critical part of the steering geometry which determines what happens when you swerve and/or brake.
You can physically vary it but until you find yourself in an emergency situation you can't guarantee the car will do what it's designed to do.
I imagine a few points like you are suggesting would be OK, but the fact that they are 7" wide, not the standard 6" of factory 16" wheels may have some bearing on it. They may need a bit less than the 50 in order to avoid rubbing on the sub frame on full lock.
I had to Google what ET is. According to the reply, "The offset is described by the term ET, which is from the German word 'Einpresstiefe' translated as 'insertion depth'"
We just say "offset"
So, in short, I can't give you a definitive answer.
 :welcumwagon:
 I can't help with your query, but would like to suggest that you modify your profile to add your location (country) and your model/ year of manufacture. Both these things can affect the answers to some of your ongoing questions. The series 1 i30 was known as the FD model and the new sleeker shape which came out mid 2012 is the GD model.
Just checked the ET/offset on my 18 x 8's and they're 42, the previous 18's were 45 which protruded the guards a couple of mm, I know this doesn't help much with the size you're looking at but it shows there are variations as Surferdude has explained.
As Dazzler mentioned the vehicle details aren't exactly clear.
Offline giwrgos_p
    • gr Greece
What is the yours opinion for MAK WHEELS. I found these near in standard dimension.
:link: CERCHI IN LEGA MAK MILANO HYUNDAI i30 6,5x16 5x114,3 BLACK MIRROR 64B | eBay
I quite like them!
Thanks for updating your profile.  :goodjob:
Offline giwrgos_p
    • gr Greece
I quite like them!
MAK is more cheap but and I can't find the right dimension :(
