Quote from: 847563 on February 08, 2012, 12:05:05Welcome to the club, as there is a glow plug for each cylinder, it would be very unlikely that ALL the glow plugs are faulty. It is either a fuel issue, or an electrical component that supplies ALL the glow plugs. I suppose there is a possibility that the glow plugs have failed over a period - one at a time - allowing the healthy cylinder(s) to get the car started. Once the healthy cylinder(s) get the engine turning at speed, the high compression ratio will fire the remainder. After the last remaining glow plug gave up the ghost - then none of the cylinders want to fire.Just a random thought - I had a think and having thunk thought it thoroughly theraputic to pass on my theoretical thinking. Thanks are not necessary..........
I have a 2010 1.6 CRDi, which has gone about 25000 km.Enginewise, it has run well, until this winter came. When the temp dropped below freezing it got more and more difficult to cold start. The start engine is turning, but it seems that there is no spark. It has helped when I pressed the gas a little bit though. But when the temp is below -10C, the car is more or less impossible to start. I always, even in the summer, wait until the glow plug lamp turns off before I start the car. Now, when it doesn't want to start I tried to turn the key, let the lamp turn off, turn the key back, turn it on until the lamp turns off, etc for a couple of times before starting, but it doesn't seem to make any difference.The car is in the workshop now and they say that the glow plugs are finished.Is it really normal that the glow plugs need to be changed on a 2 years old car, with such a low mileage? Could there be something that makes the plugs deteriorate this fast?
My glow plugs where replaced after just 3 months, 2 years later need another 2, will be covered under warranty though.
Surely consumables are items that are replaced at servicing time eg oils, filters etc. Glow plugs don't appear on the service schedule.
nope, glow plugs are a warranty item, just had mine replaced.
Which country are you in mantaray
Quote from: mantaray on December 09, 2012, 05:21:07nope, glow plugs are a warranty item, just had mine replaced.Which country are you in mantaray
