i30 engine shake & RPM up and down !!
Offline Ipgoogle
    • ps Palestinian Territory, Occupied
      Ramallah
hello ,
i have i30 2008 1.6 vvt petrol .
form week till now i have problem in it , when i drive my car for along time and along way ( 50km and more ) then try to stop on light ( on D of course ) , the RPM go down (400) and up to normal , when RPM go down the engine start shakes like the car it will turn off , and some time its turn off while A/C ON .
This problem just happen with me when drive on long way but in the city i have no problem ( in morning on short way i have no problem )
SO, i clean the IAC valve , and throttle ad change fuel filter and check idle speed every thing is OK . but the problem still happen and its feeling more when A/C ON .
So what to do now , please help
  • hyundai i30 vvt 1.6 2008
The AC imposes a rotational load of approx 5 bhp on the engine when operating. I would suggest that there is a sensor which has given up the ghost dependent on temperature of the engine.
Offline Ipgoogle
      Ramallah
i make a computer scanner and there is no fault at all , and no error code everything is fine on computer !
what sensor name you mean that have effect on temperature of the engine ?
I'm not sure. I've checked the manual but no mention. However the ECU Engine Control Unit may be where it is sensed. I will refer your problem to our world class Hy mechanic who may help. Please be patient for his response.
@cruiserfied
Offline Ipgoogle
      Ramallah
@cruiserfied
OK , i will wait . and thank you for your time & help
Heya mate,
Not a common concern at all.
From what you have mentioned it does sound like an idle control issue. You mentioned cleaning the IAC? Is your throttle cable or fly by wire? The 1.6l im familiar with is electronic throttle and the idle control is integrated in the throttlebody.
Offline Ipgoogle
      Ramallah
Heya mate,
Hello sir ,
Yes i have electronic throttle , and its apart of throttle body the mechanic told me that he clean it and put it back.
So , what you think should i buy a new IAC or new throttle body with IAC ?
BTW this video show what happen to RPM when i stop ( when speed become 0 zero)
Thanks for helping    :victory:
« Last Edit: October 20, 2016, 18:17:38 by Ipgoogle »
I don't know what you will need to fix it, can't say over the interweb.
I dont even know if you can buy the idle control seperate to the throttle body. But it does follow those characteristics.
Has your mechanic experienced it happening?
Offline Ipgoogle
      Ramallah
Hello again,
I visit a lot of mechanic and every one say different from other , thats why i ask here to know problem , anyway i think i can change just IAC with out all thrrotel body and if i cant i will change it all.
But i think its not cheap so i will ask first
