Quote from: TheReaper on March 28, 2014, 10:29:54Quote from: Phil №❶ on March 28, 2014, 10:03:20Wear out the tread, how. As long as the L & R tyres on the same axle are the same circumference, I can't see how that would happen. Having different depth changes the handling and stablility of the car, and changes the balance of the car being that they are at different depth. The car isn't running on a uniform plane, and you are angling the car front or back, depending on where you put the new tyres (usually should be done on the back axle). It's slight measurements, but it makes a big difference. I did do the two tyre thing a couple times and it always seemed that the tires didn't last as long, not too much difference, but probably an extra 10-15000km loss than doing the 4Sorry, but I don't agree. Angling the car one way or another is at best a technical description, that would only apply if you were driving on an absolutely flat surface. There are many distortions and angles of incline / decline to offset any variation, remember that we are only talking mm of difference.The only difference I can see that could enter into the equation would be the wet weather performance and aquaplaning, obviously the rears would not be as good as new fronts. Now we have ESP & ABS to assist if necessary. I don't drive to extremes in any event.
I think if I parked a car on any road where I live, none of the tyres would be on the same horizontal plane. It is not possible for a road making machine to even lay bitumen to the accuracy that you're describing, then there is wear and tear on the road surface, uneven compaction etc. so a couple of mills aren't going to be noticed. If the car is moving the suspension is constantly acting and reacting to road surface variations.Cigarettes are bad for you.
Quote from: Phil №❶ on March 28, 2014, 10:42:18Quote from: TheReaper on March 28, 2014, 10:29:54Quote from: Phil №❶ on March 28, 2014, 10:03:20Wear out the tread, how. As long as the L & R tyres on the same axle are the same circumference, I can't see how that would happen. Having different depth changes the handling and stablility of the car, and changes the balance of the car being that they are at different depth. The car isn't running on a uniform plane, and you are angling the car front or back, depending on where you put the new tyres (usually should be done on the back axle). It's slight measurements, but it makes a big difference. I did do the two tyre thing a couple times and it always seemed that the tires didn't last as long, not too much difference, but probably an extra 10-15000km loss than doing the 4Sorry, but I don't agree. Angling the car one way or another is at best a technical description, that would only apply if you were driving on an absolutely flat surface. There are many distortions and angles of incline / decline to offset any variation, remember that we are only talking mm of difference.The only difference I can see that could enter into the equation would be the wet weather performance and aquaplaning, obviously the rears would not be as good as new fronts. Now we have ESP & ABS to assist if necessary. I don't drive to extremes in any event. but whether you were on an incline or a decline, your car in relativity to slope is still in a straight line, so the uniformity is still present with four new tires,
How so? I can see that from a point of wear that you would not want to wear out the old tyres, since a front wheel drive wears fronts down faster. But as for, lets say, aquaplaning, you want the better treads in the back. So you have better traction and push out the water more efficently. Since your front tyres lose control. If you have the new tyres in the front and aquaplane and have little tread in the back you could lose all traction.
But the only thing is, if you do aquaplane with those new tyres on the front, and the ones in the back are low or somewhat low, you are out of luck. Sort of like gambling and going all in vs holding some chips back to cushion a lose. Most rain isn't going to do much in the way of aquaplaning, but we do get some crazy downpours. And as for punctured tyres. Most tyres that go flat are in the back. Usually nails get spun from the front tire going over them and shoot backwards. Not all the time but majority
@ TheReaper,Being a new member (congrats by the way on the colour change - happened at 100 posts ) you might not have noticed that Trevor (surferdude) is our Tyre Guru 40+ years in the tyre industry .. You are allowed to have your opinion but you won't win many tyre debates with Trev! You can be our first aid Guru!
Quote from: Dazzler on March 28, 2014, 21:31:31@ TheReaper,Being a new member (congrats by the way on the colour change - happened at 100 posts ) you might not have noticed that Trevor (surferdude) is our Tyre Guru 40+ years in the tyre industry .. You are allowed to have your opinion but you won't win many tyre debates with Trev! You can be our first aid Guru! lol dazzler
Nice to see that no one got their knickers in a knot, over having different points of view. & congrats on the 100 post milestone, Grim.
As an aside, what happens when all 4 tyres are low on tread? Because it seems that the argument stems around where to put too 100% brand new tyres. Wherever you put them, they will make a difference.Apart from my first XD, where the dodgy front end had an appetite for tyres and putting new tyres to the rear was a way of getting more life from them before the inevitable wheel alignment/ball joint failure, my personal opinion has always been to put them to the front, because apart from the 0.01% of the time I might be subject to aquaplaning, I will be using the wheels to steer (and now drive) the car 100% of the time. If I do need a sudden change of direction in the wet under heavy ABS, I want the best tyres doing the heavy lifting.That said, I now rotate my tyres to ensure they all die together, so I will replace all 4 anyway.Hope nightwork was uneventful Reaper.
Quote from: Phil №❶ on March 28, 2014, 21:53:54Nice to see that no one got their knickers in a knot, over having different points of view. & congrats on the 100 post milestone, Grim. lol. No knicker knots here. I do love a good debate, and no hard feelings. And thanks! By the way, what are the milestones set at? And color changes? Sorry, don't have a computer at the mo. Using tapatalk, which is not as good as the website
Quote from: TheReaper on March 28, 2014, 22:05:36Quote from: Dazzler on March 28, 2014, 21:31:31@ TheReaper,Being a new member (congrats by the way on the colour change - happened at 100 posts ) you might not have noticed that Trevor (surferdude) is our Tyre Guru 40+ years in the tyre industry .. You are allowed to have your opinion but you won't win many tyre debates with Trev! You can be our first aid Guru! lol dazzlerReaper would have some good drugs too.....
Quote from: TheReaper on March 28, 2014, 22:07:48Quote from: Phil №❶ on March 28, 2014, 21:53:54Nice to see that no one got their knickers in a knot, over having different points of view. & congrats on the 100 post milestone, Grim. lol. No knicker knots here. I do love a good debate, and no hard feelings. And thanks! By the way, what are the milestones set at? And color changes? Sorry, don't have a computer at the mo. Using tapatalk, which is not as good as the website1, 10, 100,300,500,1000,2000 (my next one is 40,000)
