So for some reason, my economy hasn't improved over the past 14000 km. yet fuel use when commuting to work and back averages at 4.8L/100 km in 70kph traffic, yet 800km with an average speed of 92kph gives 5.0.
When I refill, I fill it to the brim, I think it's a good way to be sure of the same amount of fill level with each tank, if you can actually see the fuel level. I use an app called road trip to track fuel usage, and it's usually 0.2 to 0.5 L/100 more than the cars trip computer, so I won't get a real usage figure until the next refill when I head home, with the tank brimmed every time I average 950 to 1000km to a tank, and get an average of 53 ltrs in it.
I wonder whether there are inaccuracies in the gps at civilian level. I know at military level the accuracy is much better, how much better is probably a secret. Maybe Fatboy knows more about this.
Thanks Fat Boy, interesting, so if your excellerating the GPS speedo has to catch up & speed it's reading out is slower than actual?
I think, if you ever got booked for say 1kph over limit, all this information we have could be useful. to prove nothing we have at our disposal is 100% perfect so the speed camera's should allow 10% error.
My GPS confirms pretty much what Martin had to say re speedo error.....
Phil, I think you'll find the GPS is the more accurate of the two as car manufacturers have to comply with the Australian Design Rules relating to Speedometers which stipulate they must not show less than the actual speed of the vehicle. There is an allowance for error of 10% so manufacturers err on the side of caution rather than run the risk of failing the ADR.
I'll go out on a limb and forecast that nearly all owners would report the same type of error and the similarity only proves what I said above, not that your speedo is inaccurate. It's a GPS data update issue.
