Thanks... definitely worth a go!Though I have another interesting lead - My Exhaust gas temperatures seems very strange - When the car is off, it always reads 104c, and generally stays around the 200c mark while driving which seems a bit low I think!?Curious if this 104c when engine off is a common quirk, or a strong indication that my sensor is off. Do these numbers seem unusual based on what you've seen from your car? (image attached)
I replaced the pressure sensor - This certainly improved the readings :Engine off went from 04hpa to 0hpaIdle went from 28hpa to between 0hpa and 15hpa depending on whether measured before or after a regen.However, this has unfortunately made zero difference to my regen intervals after about 700miles of driving. The distance between Regen completions is still consistently between 110km-140km.I was expecting some improvement after seeing the much improved pressure readings, I'm wondering if there's a way to register the new sensor in the ECU without going to a Kia dealer, as it appears like the ECU is not adapting to the new sensor.I'll remove the dpf for a thorough clean in a month or so if things don't improve (seems unlikely that they will).
