We have very hard water that leaves hard white spots after washing.
I've found a great technique that leaves no spots. Here it is below. How do you do it?
Wash the car with your favourite neutral hp wash (Meguiar's have a great wash liquid) and hose it off. I've found micro-fibre mittens excellent. Just make sure you don't pick up tiny stones which could get stuck in the fibre. Regularly recharge fibre from the bucket giving it a shake to remove grit. Don't touch the bottom of the bucket!
Have prepared a third of a bucket of water with half a cup of Mequire's Ultra Detailer added or your favourite detailer.
Using a micro-fibre cloth (or chamois) dipped in the above prepared solution, wipe of excess water then quickly buff with a dry micro-fibre cloth. The buffing cloth will become damp by the end but don't worry, it still works.
If you want to get really carried away, spray some pure detailer on the wet spots as well prior to wiping with the chamois or micro-fibre.
You will be left with a spotless finish
Are there any other techniques you've found good?
