2009 1.6lt diesel ecu fault now no immobiliser key light
Shrek73 · 36 · 8306
Just another question, are you using a multimeter for these checks?
Offline Shrek73
      South Australia
The car is Auto. The Auto locksmith had a machine that detected a mag field when the ignition was turned on. This car does not produce one and even with the antenna coil unplugged I have no voltage at the plug everything that is in this circuit has been replaced including the coil. I have no immobiliser light at all it hasn’t come on once since the car stopped starting. I don’t know about any codes when the auto locksmith plugged in his diagnosis tool he said there were no codes. Is there a way I can check without a OBD tool
  • I30
Offline Shrek73
      South Australia
Multimeter and a test light for checking voltage at the plugs and fuses. I would assume it won’t be a full 12v maybe 5 volts but I have the range set low as well as high so I should get something to register I also have a max hold function that will detect a voltage spike
  • I30
Information not  previous obvious, how I'm reading this saga.
" Once ECU was replaced all checked out ok apart from this issue with no power to the antenna coil"
I was working with IMMO light, no antenna power, not that I fully understand what's going on here
I would follow the fault finding steps I listed and report the results on each
I presume the Room LP 15a fuse has been checked? Even swap it if you have a spare
 :wss:
