BigTone.I can recall a similar issue mentioned not that long ago. .
Ok. Thanks for those answers. I did think it must be something on the fuel side of things. Re the dpg regenerating. Should it do it that often. I don’t do much more than 500 miles a week and it seems to be doing it far more often than it should. I’ve driven other same model i30s and they didn’t do it. As for the ecu being up to date I don’t hold out much hope of ‘clown cars’ being able to sort that!!Many thanksTony
Quote from: BigTone on February 10, 2018, 19:36:25 I don’t do much more than 500 miles a week and it seems to be doing it far more often than it should. Only diesel i30's with DPF will do it. Most of us Aussie members can't relate as the i30 diesel only had the DPF added in the latest (PD) model over here.
Quote from: Dazzler on February 10, 2018, 20:36:25Quote from: BigTone on February 10, 2018, 19:36:25 I don’t do much more than 500 miles a week and it seems to be doing it far more often than it should. Only diesel i30's with DPF will do it. Most of us Aussie members can't relate as the i30 diesel only had the DPF added in the latest (PD) model over here.Yes Dazz, cant say I miss DPF either. Mind you if someone was doing 500 miles a week in his diesel past my house, I might find some relief, like a shotgun,. Question: @Asterix or anyone ; Why would the car run rough when it regenerates ? The burn off is ex motor.
