GD4 i30 Android Auto
Bad Wolf · 102 · 29331
Offline jhaswell
      NSW
I had the same issue. Run the update again and it worked fine :)
  • i30
Quote from: jhaswell
@sagarbtl
Offline sagarbtl
      Newcastle
Updating twice worked like a charm..thanks..
  • i30
Offline i30dis
      NSW
OOOh man you must be sick of this already, but.....  can I have a copy of the file too? Please?
  • 2016 i30
Who's next ??  :rofl:
It's looking like a dedicated link in a 'support' section would let Shambles get some quality time. :lol:
Offline jhaswell
      NSW
Hey @Shambles do you know if this update will also work with i30 GD3??
  • i30
... do you know if this update will also work with i30 GD3??
I cannot say for sure, so don't try it until someone else can confirm.
I believe @GreyBanna may have a GD03 and tried the upgrade...?
Offline CraigB
      Perth, WA
I've got a GD03 non satnav head unit and the firmware update suits that model.
Offline GreyBanna
The instructions for the update file state that it is designed to update the following "Hyundai Audio Models" (Aka the head unit / stereo units or however you refer to them);
- TL-01 (TL-01 unit found in the Tucson)
- DM-01 (DM-01 unit found in the Santa Fe)
- AD-01 (AD-01 unit found in the Elantra)
- GD-03 (GD-03 unit found in the i30)
It worked a charm in my GD-03 unit, make sure to read included instructions as some models will have to be updated twice to bring all software for the various systems within the head unit up to the revision number listed in the instructions)
  • i30 SR 2015
Offline titreano
      Nottinghamshire
Any chance i could get a copy of the file too?  Is there an obvious way to tell if the Head unit is a GD-03 vs a GD-02 without getting it out that anyone knows of?
  • 65 reg 1.6 CRDi i30
Quote from: titreano
Sure thing Mr Tit. Check your email. Usual precautions apply.
Offline titreano
      Nottinghamshire
Offline Shimron
      Australia
Could I also ask please for the link to the firmware?
  • i30
Quote from: Shimron
Sure you can :D
Offline Stomp
      ACT
Hey would anyone mind sending me the file too? I've been searching google for the past hour and can't find it to download.
Cheers,
Edwina
  • Hyundai i30 2013
^ check your inbox
Offline Stomp
      ACT
3 cheers for @Shambles
Cheers !, Cheers !, Cheers !   :D
@Shambles    :goodjob:  :goodjob2:
Offline terabite7
    • gr Greece
      Greece, Athens
Hello everyone, I just purchased the GD-03 headunit and since I am from Greece there is no update from the dealer for this headunit available. I just saw this thread here, can some send me the update file, please? Thanks in advance  :)
  • 2015 GD 5 Door Hatch, Diesel 1.4lt, Manual, White
^ watch yer inbox for an early Xmas present ;)
Offline terabite7
    • gr Greece
      Greece, Athens
Thanks mate, can't wait to get the file and test it ;)
Offline timoc
      VIC
Hi there, if possible could I please also have an early Xmas present?
Just took ownership of a new Highlander MY18 and can't believe Android Auto not installed :(
Would be much appreciated if you get a chance.
Cheers,
Tim
  • Tucson Highlander MY18
Ok Tim, it's on its way. Usual caveats apply - if it screws your system don't blame us ;)
Offline timoc
      VIC
Wow, so quick!
Thanks Shambles, greatly appreciated.
Cheers!
Offline timoc
      VIC
Wow, so quick!
Cheers!
Buggar! No luck here.
Copied the file tll3000h.hdf as is on to a freshly formatted USB stick and inserted into the USB socket with Audio system on. Just got the message "no media files found" (or something close to that)
Think I will need to ring the dealer tomorrow. The mY18 is fully advertised as supporting Android Auto, so no idea why it is no istalled good to go.
 :disapp:
Thanks again for the assistance!
Offline CraigB
      Perth, WA
Wow, so quick!
Cheers!
 :disapp:
Luckily you didn't brick your head unit  :eek: the file is for different model stereo :whistler:
Offline timoc
      VIC
Wow, so quick!
Cheers!
 :disapp:
Yeah, disaster avoided thankfully.
Closer inspection on the details of the Tucson, and it seems the latest Highlander model still does not support Android auto. I was deadset keen on having it, and when I decided to go with the more expensive HL, just assumed that Android Auto would be included due to the fact it was available on the lower models. Lesson learned :(
Does anyone know if it is actually possible to have it installed at a service dept, or does it just not support it at all?
Wow, so quick!
Cheers!
 :disapp:
I'm sure if it was that easy it would already be installed UNfortunately. Very frustrating for you. Must be slightly different stereo for some reason? Guessing you get other features.   :undecided:
