2010 i30 Hatch CRD Ignition switch won't unlock on hot day in sun
Mazzo · 6 · 3749
Offline Mazzo
      Eaglemont, Victoria
When car has been standing in sun on hot day the ignition switch remains locked. Removing and replacing key several times and sometimes moving steering wheel eventually solves problem. In cold weather no problem whatever. Any views appreciated.
  • i30 Hatch CRD 2010
Offline cruiserfied
  • Crooked-H Hero
I have an idea but not something you can do at home.
Next time it happens try rocking steering wheel back and forth.
Offline Mazzo
      Eaglemont, Victoria
Problem was solved by replacement of ignition switch barrel.
Thanks for update Mazzo
Offline baroudeur
It's a known problem.  Most dealers lubricate the key which usually cures the problem of sticking pins.
Offline PhireSideZA
  • French Diamond Driver
    • za South Africa
      Port Elizabeth
  • Phil her up!
I also had this once or twice when summer arrived, but I squirted some graphite powder down the ignition barrel and it seems to be better now :goodjob:
