Why mate? You damaged one? I know they have problems with them in Europe becoming frail with corrosion and stuff, but I love the convenience.I check mine regularly. Handy if you go on a bit of rough road and it feels/sounds like you might have a flat.
Quote from: Dazzler on May 23, 2018, 10:32:54Why mate? You damaged one? I know they have problems with them in Europe becoming frail with corrosion and stuff, but I love the convenience.I check mine regularly. Handy if you go on a bit of rough road and it feels/sounds like you might have a flat. Putting a new set of boots on the beasty and don't wanna strip fit the originals to grab the sensors from em.
Quote from: Cookie Thumper on May 23, 2018, 11:08:32Quote from: Dazzler on May 23, 2018, 10:32:54Why mate? You damaged one? I know they have problems with them in Europe becoming frail with corrosion and stuff, but I love the convenience.I check mine regularly. Handy if you go on a bit of rough road and it feels/sounds like you might have a flat. Putting a new set of boots on the beasty and don't wanna strip fit the originals to grab the sensors from em.Fairy Nuff. Hope it's not too hard to find something compatible.
Quote from: Dazzler on May 23, 2018, 11:17:13Quote from: Cookie Thumper on May 23, 2018, 11:08:32Quote from: Dazzler on May 23, 2018, 10:32:54Why mate? You damaged one? I know they have problems with them in Europe becoming frail with corrosion and stuff, but I love the convenience.I check mine regularly. Handy if you go on a bit of rough road and it feels/sounds like you might have a flat. Putting a new set of boots on the beasty and don't wanna strip fit the originals to grab the sensors from em.Fairy Nuff. Hope it's not too hard to find something compatible. Should be easy to find but it is the cost Iam concerned with, if they are too expensive I'l do the strip fit.
Quote from: Cookie Thumper on May 23, 2018, 11:20:42Quote from: Dazzler on May 23, 2018, 11:17:13Quote from: Cookie Thumper on May 23, 2018, 11:08:32Quote from: Dazzler on May 23, 2018, 10:32:54Why mate? You damaged one? I know they have problems with them in Europe becoming frail with corrosion and stuff, but I love the convenience.I check mine regularly. Handy if you go on a bit of rough road and it feels/sounds like you might have a flat. Putting a new set of boots on the beasty and don't wanna strip fit the originals to grab the sensors from em.Fairy Nuff. Hope it's not too hard to find something compatible. Should be easy to find but it is the cost Iam concerned with, if they are too expensive I'l do the strip fit.I bought a cheap set off ebay for around $100 all up, but they were crap compared to the ones on the new i30. I wonder if the wheel and tyre place can do you a good deal with compatible valves included.
