Login
Register
Menu
Home
Forum
Search
Gallery
Help
Contact Us
June 07, 2025, 18:39:06
GOT PROBLEMS OR ISSUES?
DIESEL
Brake issues
Brake issues
skalra63
6 ·
2882
« previous
next »
Print
Pages:
1
Go Down
skalra63
2nd Gear
26
England
Northampton
Brake issues
January 29, 2012, 18:38:29
My brakes seem to be making noises when braking - usually for the first 3 or 4 brakes of the journey.
I have been told that this is likely due to oxidisation on the brake disks - which is fine...but should this be the case when left for 8 ish hours unused?
I think it may be related, but over the christmas/new year period, my car was unused for a week. The brakes were stuck and it was a chore to reverse out with heavy acceleration in order to unstick them
Is this normal?
Admin
Retyred @ Last
43,395
England
Re: Brake issues
Reply #1: January 29, 2012, 18:50:05
I just got back from picking my lass up (2 miles away) and I had to engage reverse to get out of my driveway. Normally I let it roll backwards as it's on an incline but my brakes were bound tightly, and I only used it for a shopping trip 7 hours ago
So, I'd say it was normal, and yes mine also makes scraping noises for a short while
Ioniq MY2018 SE Premium Hybrid in Polar White with added oomph
Asterix
V.I.P
i40 CRDi 100kW 2013
4,434
Denmark
Re: Brake issues
Reply #2: January 29, 2012, 18:51:12
Hi
If you left it for a week, it would be normal, depending on the weather, can't see where you're located.
This thread is about the same issue:
https://i30ownersclub.com/forum/index.php?topic=12800.0
You might be able to brake it away, by using your brakes hard, to make sure you brake away the rust on the brakediscs.
If you allways brake with a light foot, the rear brakes will not be activated. Under normal conditions the brakeforce is approx 70/30 front/rear or even 80/20. If you have more weight in the rear, there will be more brakepower to the rear.
i40 CRDi 100 kW 2013
eye30
Global Moderator
HOS BOSS
27,402
England
Wirral, UK. - 1.4 Petrol Active - Aqua Blue
Re: Brake issues
Reply #3: January 29, 2012, 19:04:15
Quote from: skalra63 on January 29, 2012, 18:38:29
Is this normal?
On my car it is...
1.4 Petrol Active I'm no expert, so please correct me if
skalra63
2nd Gear
26
England
Northampton
Re: Brake issues
Reply #4: January 29, 2012, 19:11:12
Thanks guys
noels_hobby
2nd Gear
35
Re: Brake issues
Reply #5: February 05, 2012, 16:05:25
have had similar issues with the old car i had brakes would lock on rust on disks ect the composite material in modern brake linings can bond to the disks when wet, i am not sure why it happens but it can tear bits of the brake lining and leave them attached to the disk. it can also lock the handbrake on. so don't hose the dust out of your brakes or soak them when washing the car !
it can be expensive to fix
cheers noel
Print
Pages:
1
Go Up
DIESEL
Brake issues
Search
Username
Password
Always stay logged in
Forgot your password?
