Lowness of the front bumper
eye30 · 27 · 9316
Does anyone else have a problem with the lowness of the front bumper?
Where I park in work, slight rise from the road no kerb, I sometimes catch the underside front on the road.
It happens more when I approach straight on, not so much a problem if I approach side on and then turn sterring right and park in space.
Can't say I've had that experience.
Are your tyre pressures up to scratch? 32-34psi?
Offline ozsnowman
      Central Victoria
I've had that happen on a few steep car park approaches, and high car park concrete surrounds are a pain too
Quote from: "Shambles"
First thing I checked.
I think its to do with the angle of the rise from road level to parking bay level.
Its as if the ground clearance between the road and bottom of the front plastic protector is just that bit low.  You can see the scuffing on the right of the plastic protector.
Does anyone know or can someone measure the ground clearance so I can check to mine.
Hi Eye,
I just measured it with a ruler (a bit hard) looks like about 18cm or 5 inches (in our driveway anyway) hope that helps.
Cheers,
Dazz
Mine's about 8"
Might be down to the rim size? I'm on 17" rims
Quote from: "Pip"
180mm is closer to 7"... :oops:  :lol:
Mine's about 8"
I would have thought the rolling diameter was the same (lower profile) maybe my driveway has a bump in it...
Offline middy
  • White i30 SLX CRDi, 5sp man. Brisbane, QLD
i've never had a problem in that area Eye, but the metal ring?? that is there to tow a broken i30, is what always hits ground on mine not the body. what you need is an adjustable air suspention :lol:
cheers
Ok been out and measured.
15 inch tyres
7.75 inches (17cm/170mm)
So it would seem height OK.
Must be slope of path/road causing problem.
Cheers for all your measurements.
Offline silveri30uk
Low front bumper-tell me about it! Just hit the front nearside bumper on Friday! My car is only 6 weeks old! A dent, 4 ins by 3 ins and 3 inc deep. No damage to paint though. Chips Away can't fix it and so I was going to a body shop on Monday.
Guess what? I try with my hair dryer and when it was nice and hot, push it from inside of the bumper, it came out and looks like as it was before! So I must have saved some £300.
Not bad hey!
silveri30uk
Not bad hey!
silveri30uk
Good thinking and good result.. That's about the only thing I need a hair dryer for these days... :-[
Offline MRH130
      Canberra
I frequently have to drive my grandparents to the doctors and their driveway is very steep, especially at the bottom. If I attack it head on I scrape too, so I come at it from the side and never have a scraping problem. Don't even scrape the mudflaps on the way down.  :D
It's a difficult thing but I guess they have to compromise the looks and aerodynamics of the car against it's practicality and ability to deal with high gutters and bumps. That's why I don't lower my cars any more - too many scratched bumpers!  :'(
Offline encountar
      Penrith
I'll admit my car is quite low, I have almost perfected the art of stopping before you hit the carpark indicators or gutters in parking lots to stop the front bar form catching, and I'm always mindful when exiting or entering any driveway to always approach on an angle.
Offline bumpkin
  • Keeping it in the family!
      Aberdeen
What's a hairdryer  :question::rolleyes: :lol:
Offline whitbomb07
      Newcastle, Australia
I've got quite a few scratches on that little plastic bit similar to eye's picture.
There's so many different ways that it can happen, best solution is to approach on an angle.
Regards
Daniel
Offline wearyone
      Durham
I think all current designs suffer from the same problem. Bring back the bolt on bumper!
My current Mazda 3 has the same problem (and scrapes) as did the Chevi Lacetti (but that was only a minor complaint compared to the rest of the car)
My Citroen ZX had the best; black soft-ish plastic. I once had a Ford Ka bump my back end at a junction, not a mark on my ZX but the Ka had a lovely crease across the bonnet.
Offline ozsnowman
      Central Victoria
Concrete kerbs at car parks can be a real pain for my front bumper. My old Commodore used to fall victim to that too
Offline whitbomb07
I think this thread has jinxed me. I now have scrape marks all along the lowest coloured part of the bumper below the grill.
I'm going to wash the car tomorrow and see how bad the damage is I'm hoping the dirt and dust isn't masking bad damage.......... :'( :'( :'(
It happened whilst doing a three point turn where the sides of the road were dirt and rock and rose quicker from the road than I expected, I thought I had enough clearance and the there was a loud scraping noise. I'm really not impressed with myself.
Anyone got good recommendations how I can try and fix it up without it being to costly?
Thanks.
Daniel
Hi Daniel,
You could either mask it and prep the area with some fine sanding paper then spray the bottom inch or two of the leading edge with a satin black spray..
or go to Autobarn or one of the bigger car dealers and see if they offer to match you paint and put it in a spray can.. then prep and spray as above..
I've done a bit of it and it's not that hard...
Offline silveri30uk
I have seen work done by Chips Away and they are quite good and cheap too. Search their website and get a quote. They will do it at your home or office address.
silveri30uk
Offline Yoshiofthewire
I bottom out all the time in the Speed Bumps in my development
The only way I don't hit the bump is if I'm going 5mph
Offline silveri30uk
Not really related to the lowness of bumper but last week a piece of black sponge fall down from the front bumper and its hanging down . I tried to investigate and pushed the sponge back to the slot but came down again today. I saw another red i30 and noticed the same thing. Like mine, its a Czech one so does any one know what this is before I speak to the local dealer?
silveri30uk
Offline MRH130
      Canberra
silveri30uk
Hi silver,
This happened to a couple of other members, with Korean-built ones too.
See this thread https://i30ownersclub.com/forum/index.php/topic,1636.0.html
Nothing to panic about too much methinks.  :D
Offline Goldfish_8
      Toytown
Oh yes, I do have the odd clearance problem.
With the body kit, 18"s and the factory lowering spring option, I can just about muster a 4 1/2" gap under the front bumper, less with worn tyres and less again with passengers and luggage!
Standard height UK pavement kerb stones are too tall!, some drives and speed bumps also pose a little bit of a problem at times!
Mark
Mark
But a great looking car all the same  :wink: :mrgreen:
