Those DPF's really are a pain in certain part of the body
In the UK, removal of the DPF can increase emission levels enough for the car to fail its annual government inspection and thus be refused a road licence.
Quote from: AlanHo on May 09, 2012, 09:43:30In the UK, removal of the DPF can increase emission levels enough for the car to fail its annual government inspection and thus be refused a road licence.That is true and the same here. But some cars even make it through the inspection without DPF. The ones that don't, find some other way (not legal) to do it (of course, I'm talking about the situation over here). And we have annual inspections when the car reaches 8 years. First 4 years there are no inspections, then between the age of 4-8 years, the car is inspected every second year and after 8 - annually.
But in your case, I would insist on replacing the filter, under warranty of course.
And as for taking that 35km trip with higher rev's. Are you sure the renereration was done?
PS: Which oil do they put in? Some services put in wrong oil (5W-40 or something like that instead of 5W-30C3), which can cause earlier DPF failure.
But the main problem are the DPF faults, that usually occur after few years (2-3) of driving like that.. The costs of DPF filter replacement are around 1,500 EUR. Good thing we have a 5 year warranty, but still... I know few people that had problems with DPF's (not Hyundai) and in the end, they took it out, "ECU-bypassed" it and drive without it.
Could you whip the DPF out and just refit it at 2 years and 11 months
So now I'm curious about what's wrong. Had booked the car for tomorrow at the dealer anyway, as the A/C will not cool any longer, and I have a little issue when starting the engine when cold. The engine only runs on 3 cylinders for a few seconds, then ok again. Think it is a dead glow plug, have asked them to check the glow plugs.Looking forward to hear from the dealer tomorrow..
So, now I have taken it for a little testdrive. 180 km, of which 130 km was motorway with speeds at 130-140 km/t, 2 times I had the opportunity to reach 185 km/t If the engine can get rid of the exhaust when doing 185 km/h the DPF can't be blocked totally. After about 100 km the LPH started to show higher consumption, so I then knew the regeneration was started. After 50 km more on the motorway again doing 130-140 the LPH dropped again, regeneration completed. Now I'm off to the dealer again tomorrow to have that flashing engine control light stop flashing, forever I hope.
Diesel Particulate Filter (if equipped) The Diesel Particulate Filter (DPF) system removes the soot emitted from the vehicle.Unlike a disposable air filter, the DPF system automatically burns (oxidizes) and removes the accumulated soot according to the driving conditions. In other words, the active burning by engine control system and high exhaust gas temperature caused by normal/high driving condition burns and removes the accumulated soot.However, if the vehicle continues to be driven at low speed for a long time, the accumulated soot may not be automatically removed because of low exhaust gas temperature. In this particular case, the amount of soot is out of detection limit, the soot oxidation process by engine control system may not happen and the malfunction indicator light may blink.When the malfunction indicator light blinks, it may stop blinking by driving the vehicle at more than 60km/h (37 mph) or at more than second gear with 1500 - 2000 engine rpm for a certain time (for about 25 minutes).If the malfunction indicator light continues to blink in spite of the procedure, we recommend that the system be checked by a HYUNDAI authorised repairer.If you continue to drive with the malfunction indicator light blinking for a long time, the DPF system can be damaged and fuel consumption can worsen.CAUTION - Diesel Fuel (if equipped with DPF)It is recommended to use the regulated automotive diesel fuel for diesel vehicle equipped with the DPF system.If you use diesel fuel including high sulfur (more than 50 ppm sulfur) and unspecified additives, it can cause the DPF system to be dam¬aged and white smoke can be emitted.
Quote from: Asterix on May 09, 2012, 20:26:29So, now I have taken it for a little testdrive. 180 km, of which 130 km was motorway with speeds at 130-140 km/t, 2 times I had the opportunity to reach 185 km/t If the engine can get rid of the exhaust when doing 185 km/h the DPF can't be blocked totally. After about 100 km the LPH started to show higher consumption, so I then knew the regeneration was started. After 50 km more on the motorway again doing 130-140 the LPH dropped again, regeneration completed. Now I'm off to the dealer again tomorrow to have that flashing engine control light stop flashing, forever I hope. Unfortunately, if the put DPF's in Australian diesels, that will be the end for me, back to petrol. Fancty being forced to do 185kmh just to clean the DPF, that is ridiculous Fortunately, Gillard is not listening to Mr Ho's submission on this matter, in fact, she's not listening to anyone.
Could you try clearing the code... maybe borrow an OBD plugin from a mate?
Sounds promising (did they make you pay for the glow plugs?)
I just re-read this thread and saw a reference to the fact that your car is 4.5 years old. It therefore surprises me that it has a DPF fitted. In the UK - to the best of my knowledge - DPF's were not fitted until late 2010 when the Euro 4 (or was it Euro 5) engine was introduced.
