Ashtray Illumination
tiny · 17 · 5980
Offline tiny
    • ro Romania
      Bucharest
i wanted to ask, for some time now, do your i30's have an illuminated ashtray?
Quote from: "tiny"
Mine has a light which can be seen when opened, when the car lights are switched on that is
Offline Waja
      Sydney, NSW, Australia
yeah, i heard that there were supposed to be lights when the headlights are switched on, but when i pulled the ashtray out and also the 12v and cigarette lighter compartment out, there was no possible way of any lighting to be wired there/no wires for lighting in my car...maybe the earlier releases didnt have the light? 07 compliances maybe?
Offline tiny
    • ro Romania
      Bucharest
a friend from hyundaiclub here  opened that thing up, he said the wirining was there and he made some mods and installed a led of his own. a thing which should have been stock.
Offline Waja
yeah, its easy to tap into the power cables behind the 12v/cigarette lighter faceplate. its how to tapped the power to run my neons to the back of the cigarette lighter...just the process of GETTING the faceplate out is a b!@tch..lol..i think that russ or somebody had put a guide/a couple of pics of how it looks, but if u want, give me a shout and i can take some more pics
Offline nikitas i30
    • gr Greece
      Athens-Greece
I installed today to my car the ashtray light and cigar lighter light.
I'll upload photos of the result tommorow
Offline babis_xo
  • 6* dummy
    • gr Greece
  • ...em ot keerG lla s'ti
I installed today to my car the ashtray light...
Looking forward for the "how to" :)
If you insist, you can install mine as well :D
 :eek: Is that what you smoke in car?  :P
Nowadays, due to our economic crisis, we should smoke drained weed wrapped in free-press (i think City Press has an adequate paper quality)  :lol:
Of course, it's better to don't smoke at all...
  • 1.4 HB Classic '09 White
Offline clackerz
  • Drivin' round Melbournes SE 'burbs in a Black SLX
A write up def would benefit others here.
@ Waja!?! I see you've got a bit of illumination going on there as well - I assume the floor lights operate when the door is opened/ajar...
Offline agentr31
  • LOOK AT ME, LOOK AT ME!!!
man... that sounds sooo suspect its not funny!
i think i know where babis gets his sense of humor from now,a little baggie.  :lol:
Offline nikitas i30
    • gr Greece
      Athens-Greece
It's easier than you think.
I followed this guide,thanx to hemmi
and this,thanx to tzwientjuh
The cables with illum power is the pink(+) and black(- ground)
Around the plastic of the cigar lighter(in the last photo) i mounted a little bulb with a tie wrap.
My next goal is to install Door lights like this by using led strips....
Offline nikitas i30
    • gr Greece
      Athens-Greece
Offline umbro
    • ro Romania
      Romania
nice, but it would have been better if you had used blue LEDs instead of yellow bulbs
I would have to agree.. I thought that myself ... :cool:
Offline babis_xo
  • 6* dummy
    • gr Greece
As a "devil's advocate" would say,
the odd feeling, resultant of the uneven illumination, helps you to stay away from smoking, by not pulling the ashtray out too often.
After all, smoking is a bad habbit.
Does the light comes on only when you pull the ashtray out and lights are on?
And if there are no screws, how do you pull out the lower compartment?
Hmmm... you're right. I should use this instead.
...cli...ick...
P.S.: to wriggle out of the situation: this is what i meant :rolleyes:
Offline agentr31
Offline nikitas i30
    • gr Greece
      Athens-Greece
The ashtray light comes on only when the lights are on even the ashtray is closed.
About the lower compartment (cigarete lighter) i pulled it out very easily.
You push the gear knob base,lift the plastic base and then pull backwards....
