How to add DRLs to the Australian version of the 2012 model Hyundai i30?
Offline rickai
      Hurstville NSW
I notice the 3 door hatch have it too as standard, just saw 2 cars this week that have the DRL on them.
That is the SE that Rusty is talkin' about  :goodjob:
Offline Dave M
      Berwick, Vic
I've just read a review of the i30 Special Edition from July 2013.
It was a 3 door and had DRL s as standard. I think it was built in Europe which is probably why they're fitted.
Don't know if it's still available now.
The one I saw on Coles was a 5 door.
  • 2014 MY i30 Elite Manual Hatch. Dazzling Blue
Offline avexdevil
anyone in perth capable of installing DRLs on my i30 for a small fee (6 pack? Dozen? Carton) :P?
  • i30
Take an Easter drive to Adelaide and I'll have a go. :happydance:
Offline Zoom
      Dandenong, Melbourne
Phil, those tapes looks pretty good, how well does that go with heat? Is that the same thing that hyundai use for wrapping around the electricals in our cars?
Having used all of these products in my trade, I found Amalgamated tape will peel off if you dont tape the end with insulation tape.  Insulation tape doesn't work well if there is heat or water.  The best method, and the only one I use under my hood, is to solder, and then protect the joint with Raychem glue lined heatshrink.  You will never get water in the joint.  You can by it at Middys / Auslec or any electrical wholesaler.
I also wouldn't recommend the splice connectors, even if you adhere to the conductor size recommendations, the ones you buy in super cheap auto...are just that, cheap crap.  One incorrect join, especially on a circuit carrying a higher amperage can mean an electrical fire, which i have seen the result of that.  At the very least, if you dont want to solder, use an insulated crimp link .
Zoom!  :victory:
« Last Edit: April 22, 2014, 04:12:14 by Zoom »
  • 2012 I30 Premium
