Nudge Bars and Spotlights
Just Rick · 32 · 17378
Thanks Rick, I'm certainly curious as to whether or not they are in fact illegal as nothing in the Australian Design Rules points to them being so.... :undecided:
6.1.5. In addition to the main beam headlamps in paragraph 6.1 of Appendix A,
a further two or four driving lamps may be installed as long as they
comply with paragraph 7.3 of this rule.
7.3. DRIVING LAMPS
7.3.1. Presence: Optional on motor vehicles.  Prohibited on trailers.
7.3.2. Number:
7.3.2.1. Two or four.
7.3.2.2. To be used in conjunction with headlamps.
7.3.3. Arrangement
No individual specifications
7.3.4. Position
7.3.4.1. In width no individual specifications.
7.3.4.2. In height: no individual specifications.
7.3.4.3. In length: at the front of the vehicle and fitted in such a way that the light
emitted does not cause discomfort to the driver either directly or
indirectly through the rear-view mirrors and/or other reflecting surfaces
of the vehicle.
7.3.5. Geometric visibility
No individual specifications.
7.3.6. Orientation
Towards the front.
7.3.7. Electrical connections
The driving lamps must be able to be lighted only when the main-beam
headlamps switch is in the “lamps on” position.
7.3.8. Tell tale:  No requirement.
7.3.9. Others
The aggregate maximum intensity of the main-beam headlamps as
specified in paragraph 6.1.9.1 of Appendix A can be exceeded with the
fitment and illumination of driving lamps.  Driving lamps do not have to
comply with ADR 46/….
Below is a Vehicle Standards Instruction pdf regarding auxiliary lights.....although it's Queensland based I'd assume it's probably similar in other states... :undecided:
http://www.tmr.qld.gov.au/~/media/5f455e92-481a-4cab-9636-7fe3e2cd2813/vsig10auxiliarydrivinglampsfittedtomotorvehicles.pdf
Offline Just Rick
  • Big Dogs Rule
      Beverley Western Australia
  • miracles can happen
Neptune
Yeah I tried going through licensing online
