0 Members and 46 Guests are viewing this topic.
Thanks Dazz.Yep, maybe fuel (whatever), that was my thoughts. It is flat out at approx. 30mph in the 4th. Intially they thought it could be water in the fuel filter, but they say all ok. They have always serviced the vehicle; as it was due. Engine runs fine, starts easily, just won't rev.On two occaisions, it has occured when the fuel guage indicates just under half, and I have simultaneously floored it. I usually fill with Esso.
Thanks Dazz, I have previously read these reports, one is significant; if you accelerate around a fairly tight corner, under half full, the problem manifests.I have tried to tell the Service Receptionist, who repeatedly, as I have noted, does not absorb this helpful information.
That's a terrible story Aaron
Limp Home Mode has started again. Braking, then accelerating out of a slow left hand turn, with the tank full.(Previous occasions, under half full, and right hand turn).ESP comes on, initially hesitant on acceleration, then into Limp Home Mode. Lifting foot off pedal seems to clear itself and accelerates, ESP light still on, pull up, switch off, starts working OK for a short time Back to Dealership, yet again.....
has the fault been fixed yet?
Finally a faulty unit found, good to hear... Hope this will solve all the problems...
