Thanks for the welcome everyone! I'm enjoying driving the car! I live in Sydney, NSW.
I will post some pics of the red rocket soon! It just had it's first service. I do have a couple of questions!!!
Do any of you use e10 fuel? and if so, what are the benefits & what are the problems? Also, what are the benefits of driving in eco mode? Thanks!!
i've driven Toyota, company Vans on e10 they get replaced every three years and clock up 130,000k we have two the lease co fuel card is only good for e10. i've never seen a problem that way. but i work on my own hobby motors tuning i got a used motorcycle about 6 months ago, the last owner had run it om 95 octaine i took intake manifold off to check & i could see carbon build up on intake & valves 70,000k up , i only use BP 98 ultimate i just took the heads off the motor on monday and after 10,000k on BP 98 ultimate the intake valves & intake ports were clean like new. some pitting on valve seats this is just normal from unlead fuel, will service heads hone bore new rings. just thought i'd mention this. as once every say three tank fulls of e10 i would use BP 98 fust to keep injectors clean, also a clean intake port helps keep motor performing at its best.
