engine getting hot
bobbyd · 47 · 13528
Offline bobbyd
I have an ultra gauge installed on my crdi I30.  its a great little unit giving all sorts of info read outs.  I've noticed that going uphill (as in up the long freeway) the engine temp goes from 85 degrees (thermostat temp) right up to 105 at times on warmer days or even 94 ish on mild days (eg 20 c)
The temp rises very quickly, indicating to me that possibly the thermostat doesn't flow all that well.  The temp goes back to normal as soon as you back off at the top of the hill.  The car is well serviced and had its coolant changed on schedule. The factory temp gauge barely moves but i dont hold faith in that being a good indicator.
Took it to a radiator place and he measured it as a 12mm thick core, reckons its the thinnest radiator he has ever seen on a car and silly given the 46mm tanks.
Anyone else noticed increasing temps going uphill?
Anyone replaced radiator or thermostat ?
Ive noticed the same thing with my scangauge II. when the temp goes up into 100+ the gauge in the dash doesn't move what so ever.  :Shocked:  the average normal temp is about 84,but Ive seen the temp hit 108.  :sweating:  turning on the aircon makes the temp go down to normal,but only due to the aircon condenser fan.  :eek:
Could the coolant temp be sourced from 2 different sensors  :question:
Is there a danger that scan gauges and their brethren cause you to worry about things they reveal that would not be a problem otherwise?... :scared:
i can remember reading a post about an i30 dropping a radiator hose and it loosing its coolant. the owner noted the temp gauge only going to the half mark and no higher. he mentioned that the only reason he knew something wasn't normal was the very hot smell of his car when he parked his car in garage. he looked under the bonnet and found the expansion tank empty and also the radiator. the next morning he checked where the water had been lost from and found a radiator hose had somehow come off.  :sweating: :scared:
both the ultra gauge and scangauge II plug into the OBD port under the dash. the readings they display are direct from the ECU.
The question then is - where is the sensor the ECU depends upon and is it the same one as is used by the temperature gauge?
I figured the ECU would have that info, but does the info come from the standard temp sender, or somewhere else. Temp is an important factor in determining the amount of fuel the injectors deliver. The ECU needs to know what the engine temp is doing more precisely than the driver. So the ECU could be accurate and the driver info, very average, although duplication would add cost and complexity. Don't know why they would do that.  :undecided:
on my 2.0 petrol engine the water temp sender unit is on the cylinder head,on Bobbyd's 1.6 crdi I'm fairly sure its also on the head.  :undecided: but there could be another one on the engine block or on the radiator.  :undecided:
Normal for any motor to get a bit hotter when under load like pulling up a big hill. HP generates heat.
Offline bryanj86
      Logan
I know a way of cooling it down better...hehe!!  Do what they used to do in the 90's with the old Comodores;  Take the grills off !! haha!! so there are huge holes letting the air in with no decorative grills to impede the flow! lol I would certainly work but make the car look horrible!
People often do it to older cars when they are giong out west towing trailers etc....
  • 2011 Crdi i30
What about birds & stones  :eek:
Offline bryanj86
      Logan
You just pull them out! lol  One doesnt normally follow too much traffic out west?
  • 2011 Crdi i30
One way to cool your engine down is to put on full heat and cabinfan on full throttle.
It's not nice, but it cools down the engine pretty fast.
that works.  :goodjob2: :goodjob:
Offline bryanj86
      Logan
They say to do that any time you notice  your car overheating, yes. Before you stop and promptly turn the engine off lol
  • 2011 Crdi i30
Offline bryanj86
      Logan
ANOTHER thing is to CHECK YOUR WATER frequently! My work colleagues have this warped perception that the mechanic only needs to do it every 6 months or whenever they go to the mechanic.  I challenged them both and they allowed me to open their bonnets on their three cars. ALL three needed water. I could see the core of the radiator DRY in two of them! They took about a LITRE of water each. A litre isn't dramatic but it means there are airlocks going around the engine. The engine should be full of water.... not empty! haha! THAT causes a HOT ENGINE!
  • 2011 Crdi i30
They may now all sue you when their greatly diluted antifreeze/anti corrosion fails to do the job  :eek: :whistler:
Can't see the problem myself.
It could be worse than that too. If there were any deposits in the coolant, they goto the core of the radiator and through heat solidify into little rocks. this will block the core and reduce radiator efficiency.  :fum:
" I challenged them both (2) and they allowed me to open their bonnets on their three cars." :wacko:
Please be aware bryanj86 we are just joshing with you  :winker:
No offence meant, bryanj86  :(
Offline bryanj86
      Logan
HAHAHA!! I know! hehe!  Sorry... It was over the period of two day. two ladies, three cars. The first day was each of their cars then the second day i asked again one of the same ladies who had her husbands car that next day. So all THREE cars were low on water. I told them it was low and they should see a mechanic lol
  • 2011 Crdi i30
 :goodjob2: :goodjob: :mrgreen:
Offline BC
  • Melbourne, Australia
Has anyone seen the temperature gauge rise above normal due to low water or other problems?  Just curious to see if they can be relied on to indicate an issue . . .
  • I30CW CrDi
Feedback on here is they aren't very indicative of actual temperatures (at least in the FD anyway)
I.E. increases in Temp picked up by Scan gauge (and the like) not necessarily mirrored on the dash readout  :confused:
It might be reassuring to have the temp gauge showing it never gets hot, but it's not very reassuring to know it probably won't tell you even if it does.
I thought that the other day when I was driving around in 40+ degree heat and the temp gauge didn't budge.
I thought gee, that's good, or bad.  :confused:
Offline plasticphyte
  • Bazinga!
  • Bazinga!
This isn't something that is confined to Hyundai cars, I experienced similar issues with a previous car. It had actually developed a small leak in a radiator hose, and the engine was overheating a bit. It was only because coolant fluid was observed on the engine shroud that the leak was detected and fixed.
  • i30 Premium 2012 1.6l Diesel
This topic is a good example of the advantage of digital information over analogue display.
Unless it's getting dangerously hot, does the average driver really need to know more?  :undecided:
