0 Members and 12 Guests are viewing this topic.
We have some canvas one's currently on the front seat. They do up underneath the chair without bothering the electrics under there, but you can't slip the middle one through the back of the seat (we don't have heated seats-the regular one's don't allow it either). We just left it under the cover sitting on the seat. Hasn't made too much of a difference I don't think. Maybe doesn't sit quite as flush in the seam under your bottom as it should.
Quote from: panda on January 31, 2013, 00:48:59We have some canvas one's currently on the front seat. They do up underneath the chair without bothering the electrics under there, but you can't slip the middle one through the back of the seat (we don't have heated seats-the regular one's don't allow it either). We just left it under the cover sitting on the seat. Hasn't made too much of a difference I don't think. Maybe doesn't sit quite as flush in the seam under your bottom as it should.You have a seam under your bottom? I'll have to check mine again.
Quote from: db08 on January 31, 2013, 11:28:45Quote from: panda on January 31, 2013, 00:48:59We have some canvas one's currently on the front seat. They do up underneath the chair without bothering the electrics under there, but you can't slip the middle one through the back of the seat (we don't have heated seats-the regular one's don't allow it either). We just left it under the cover sitting on the seat. Hasn't made too much of a difference I don't think. Maybe doesn't sit quite as flush in the seam under your bottom as it should.You have a seam under your bottom? I'll have to check mine again. I don't know about you but I can't see my own bottom, you might need someone else to check it for you Thanks for the info guys! I'll take a look and see (being careful of spikey bits!)
OK, I'll open it up to the membership for volunteers.Offers anyone?
Quote from: panda on February 01, 2013, 08:41:36I don't know about you but I can't see my own bottom, you might need someone else to check it for you We must be careful with our English, the subject in the sentence has changed from I to you. For that statement to be correct, it should be"I don't know about you but I can't see my own bottom, I might need someone else to check it for me"
and then in flys a "birdie" ready to cover your six......
so you need to use your fingers to explore the terrain for a while in a north-south position before attempting insertion to get a good fit.
Quote from: wrx43 on February 24, 2013, 10:19:50so you need to use your fingers to explore the terrain for a while in a north-south position before attempting insertion to get a good fit.I've had this advice before.
Quote from: db08 on February 24, 2013, 10:37:37Quote from: wrx43 on February 24, 2013, 10:19:50so you need to use your fingers to explore the terrain for a while in a north-south position before attempting insertion to get a good fit.I've had this advice before.Yes, nice turn of phrase wrx43 ... you didn't help draft the Karma Sutra by any chance I suppose?
You will fit in good around here
Quote from: Dazzler on February 24, 2013, 11:42:50You will fit in good around here Tx Dazzler. How are your chrome door handles holding up? [no pun here, tempting as it is]
Back to the OP question, I bought the tailored Ilana covers from Motoquipe for my FD i30cw wagon for $140 and fitted the front seats today. What a PITA it was. I only have the SX but still plenty of navigating to do under the seats. Ended up balanced with head on floor, one foot on the ceiling and the other on the opposing door. in line with some of this thread I was so contorted I could almost see up my own rear end. Straps were tough to slide through the tight gap on the sides. So first one was tough going. Second time was not so tight because I knew where to apply pressure to make entry easier and bordered on an enjoyable experience. Tip: fit the seat bottom before fitting the seat upright. Ignore the text they call instructions and the explanatory diagram. You will be in foreign territory and so you need to use your fingers to explore the terrain for a while in a north-south position before attempting insertion to get a good fit.
... The car'll be 2 years old at this rate before I do anything about them!
Quote from: panda on February 25, 2013, 07:18:08... The car'll be 2 years old at this rate before I do anything about them!Oh, great. I won't be holding my breath over the grand home made yoghurt experiment then.
Quote from: Gonz on February 25, 2013, 07:52:20Quote from: panda on February 25, 2013, 07:18:08... The car'll be 2 years old at this rate before I do anything about them!Oh, great. I won't be holding my breath over the grand home made yoghurt experiment then. No, safer not to. I've been meaning to try making my own yoghurt for 5 years or so now (using the easiyo satchets even proves to be too much for me more often than not).
Quote from: panda on February 25, 2013, 09:46:48Quote from: Gonz on February 25, 2013, 07:52:20Quote from: panda on February 25, 2013, 07:18:08... The car'll be 2 years old at this rate before I do anything about them!Oh, great. I won't be holding my breath over the grand home made yoghurt experiment then. No, safer not to. I've been meaning to try making my own yoghurt for 5 years or so now (using the easiyo satchets even proves to be too much for me more often than not).Gee it's a wonder you ever got around to making some kids
