Quick test video from DoD F520 with custom firmware.
xreyuk · 25 · 8796
Offline xreyuk
      Southport
  • Seat Leon 1.6TDI CR Ecomotive Owner
Thought I'd post some footage from my camera, now that I'd done Alan's modification to reduce glare. I've also visited a Russian website where I was pointed to a custom firmware, which increased the video bit rate from 10Mb/s to 18Mb/s, and also added a few extra video options in the menu. It's definitely made the footage better!
Enjoy :)
That looks good. Is your camera still inverted ?
Offline meehalych
  • Aircraft technician
    • ru Russian Federation
      Kolpino
which one?
Looks slightly sharper than the footage I record.
 :goodjob: Smooth, clear footage (impressive)  :D
Offline meehalych
      Kolpino
I reckon that site is: http://f500-faq.narod.ru/
The newest firmware for our DOD is:
Q2-4.7
I haven't installed it yet, but I will give it a try once I have a time
^-- ok thanks Misha. I'll let you be the guinea pig again ;)
Offline xreyuk
      Southport
I got advice from here
It's all in Russian but one nice fellow happily explained it to me in English, and pointed me to the correct files and such. Meehalych will understand better :D
It's definitely a lot sharper and I'm really impressed. The firmware changes some of the menu options around too, and does put it in Russian, but there is an option in the menu to change it to English (go to settings, up one, right one, down fourteen, left/right)
The firmware backup and update is very easy.
Alan - I don't have it inverted anymore. One problem that I didn't think about (and only noticed when I came to use the camera), is on my car, when the wipers are off they are vertical at the sides of the windscreen, and wipe down and inwards (as opposed to up and outwards). This means the area around where the camera would be if I put it up by the rear view mirror is left unwiped, so you can't see a thing! I've settled on putting it down on the middle and very front of the windscreen.
Thanks guys :)
It's all in Russian ..
And now you've been banned from there for not posting in the mother tongue :rofl:
They've even quoted their rule book for you :P
Quite clear explanation as you say, though I think I'll pass on it, personally.
(Google Translate)
Is that thro' Ince Blundell?
I thought I recognised the area..............
Used to travel that road many times a month to go to Formby/Freshfields and Southport when I worked in Bootle.
Bad road for accidents between Thornton and the dual carriage way.
40 MPH - which part is that?
Offline xreyuk
      Southport
The 30mph is through Maghull, if you come off the M57, take a right down the A59 towards Ormskirk. Go through the first set of lights, past the Motor Range car supermarket and the esso garage on the left. You take the slip road off and go through Maghull there :)
The 40mph part is a bit later on, on the same road.
*EDIT*
This is the 30mph limit: http://goo.gl/maps/DP1K9
This is the 40mph limit: http://goo.gl/maps/GIOgS
map of the whole route recorded: http://goo.gl/maps/kkqe6
Offline meehalych
      Kolpino
I would tell you one thing - I am a participant of that forum too (I had come across your posts in "f500 from DX" thread by luck) :))
I thought it was as I used that route if I was going to the far side of Southport or the crem, going past the pub the Scotch Piper.
In the summer used to call in at a pub at the side of the canal, not far from where you stopped .
Not like me to forget pub names but have on this occasion.
« Last Edit: May 02, 2013, 20:03:35 by eye30 »
Offline xreyuk
      Southport
I must say this new firmware is fantastic, so much more detail in the pictures. The biggest difference has been in cloudy weather. Before, I couldn't read registration plates, but now with the new firmware, they're easily readable.
Alan, I'd suggest upgrading if you can!
Whilst I appreciate your suggestion, I come from the old school where our motto is "If it aint broke - don't fix it".
I am satisfied that the quality of the video I get is as good as - if not better than - the video you posted earlier. However - this may be due to you using higher compression than me in the video that you posted.
I am able to read registration plates on vehicles, including those coming in the opposite direction, quite legibly which is all I need.
When DOD issue new firmware I might consider it - but I don't have the technical skills to unravel any cock-up I might cause when playing with third party fixes.
I'm pleased you are delighted with your camera - so am I with mine.
Offline meehalych
      Kolpino
thanks  :D, I have tried to install that new firmware I told about before and I got my camcorder dead as a result, a recovery procedure didn't work, so I have reserved DOD F520LS in a local shop and I'm going to pick it up tomorrow (its price is ). At least I don't need to wait for the holder to come any longer  :D, I will get one with a new camcorder and will have got two spare when my parcel arrives.
Offline meehalych
      Kolpino
I did it! I did it! I did it! I revived my DOD and now its firmware is v1.14 T2L-KH  :happydance:
I did it! I did it! I did it! I revived my DOD ...
So it's no longer DEAD, but once again DOD :D
Good one ;)
Good one ;)
 :goodjob: :lol:
Offline meehalych
      Kolpino
:goodjob: Good news! So, can you cancel the new dod?  :undecided:
no need to do it, cause my reservation will be cancelled automaticaly if no further action comes from my side till the end of this day
DOD, that has seen afterlife  :D
