i30 CRDI 2007 intermittent radio probs (blank screen)
donnyd · 10 · 2697
Offline donnyd
      UK
 I have problems with the radio  in this car  ,screen keeps going blank hence no radio or clock ,this happens intermittently can anyone advise please.
Administrator Comment Broken capslock fixed, free of charge ;)
  • i30 1.6 crdi (2007)
Sounds like loss of + 12v or intermittent earth, generally caused by a plug not properly connected, although in a 2007 car, this should certainly have been fixed by now. Do the stations of clock require resetting.
I'm with Phil on checking your power and earth connections. Even in a car with time to have resolved any problems, if not well done, they will become dodgy over time.
My old Renault Fuego was 25 years old when I discovered it had an audio warning for leaving lights on, thanks to some unrelated wiring work disturbing the circuit back into operation.
Welcome to the forum donnyd.
It's easy enough to remove the fascia to get to the radio, to check the connections as mentioned above.
Whereabouts in the UK are you?
Offline donnyd
      UK
yes the stations and the clock require setting  I just hope its not the radio , rang dealer and quoted extort pricdwill later models i30 fit  :Shocked:
Offline donnyd
      UK
BIRMINGHAM,STOURBRIDGE
Quote from: donnyd
Quote from: Shambles
Not quite close enough for a visit from me, I'm afraid...
Does this happen when the car is jolted like over bump?
Have you checked fuses and all wire plugs are tight?
Offline donnyd
      UK
it happens if car is driven or  even if engine is switched off not sure how to get to the plugs of the unit  this first happened about 6 months ago briefly  and was fine until  few days ago, it  is  coming on and going off like a  set of traffic lights
