Thumper being the only one thats apparently had some sort of play (lots of smoke here cant see exactly what/how) so his name comes up alot, however most of his playing seem to have been to limit the i30's fuel supply to get better range which he apparently did, with the help of finding a sweet spot of sorts to get better fuel economy from IAT which apparently he did its not something ive got the time or desire it investigate at the moment.
well i can tell you i found in croatia one place that does tuning of i30 crdi 116 hp very nicethere are two versions...116 HP / 255 nm -> 140 HP / 307 nm -> 300 Euros116 HP / 255 nm -> 158 HP / 322 nm -> 500 Eurosi checked them out.. they are first hand for Bosch service and parts in Croatia. Everyone has to buy from them... and few firends told me that theyr service was clean as a lab I asked my Hyundai service... he told me i'm prety safe with tuning to 158 HP .. he know my habits of driving ... he is first choice and only place for tuning hyundai in croatia if you want done it properly... they've done 10+ hyundai conversions to turbo.. and latest is v6 2.7 coupe with supercharger .. and this thing fly's.....
The stock peak pressure is 1.3Bar (18.85Psi). If you don't want any trouble with the turbo you should not go over 1.5Bar (21.75Psi). With this pressure you're still in the "safe zone".1.6bar (23.02PSi) depending on your driving style.. the turbo will not last to long!I've been there....
ouri30,I mean the intake manafold pressure. Here is what happens when you give it to much pressure:
Ok. The MAP reported by the Scanguage II is 16.5psi with minimal acceleration. Medium acceleration is low 20psi and full acceleration without flogging it is 30+psi. I'm not one to push it to the max just to see what I can get as a maximum MAP.I would assume the MAP I am observing are well within the limits set by the ECU. These figures are outside the figures you have indicated as safe. As an adjunct to this, the MAP I am seening on my Santa Fe CRDi 2.2 are slightly higher than those of the i30.
I'm not trying to pick a fight here, just reporting what I am observing.
Quote from: ouri30 on May 26, 2009, 11:40:45Ok. The MAP reported by the Scanguage II is 16.5psi with minimal acceleration. Medium acceleration is low 20psi and full acceleration without flogging it is 30+psi. I'm not one to push it to the max just to see what I can get as a maximum MAP.I would assume the MAP I am observing are well within the limits set by the ECU. These figures are outside the figures you have indicated as safe. As an adjunct to this, the MAP I am seening on my Santa Fe CRDi 2.2 are slightly higher than those of the i30.Those values are EXTREMELY high (for a standar car)! Your readings probably have some problems, (some configuration must be wrong).The WTCC cars run at 2.5Bar which is ~36Psi. Here a video of a 2.0Tdi engine:On a VNT17 Turbo (capable of more bost), instead of the VNT15 that the I30/Ceed have!Quote from: ouri30 on May 26, 2009, 11:40:45I'm not trying to pick a fight here, just reporting what I am observing. No problem. It's a forum... everyone should give their input on issues! andrejs,I have a 115bhp Kia Ceed (remaped). It's a I30 on a different body shell. From what I've read from a Kia mechanic on a different forum, the only difference on the 90bhp and the 115bhp is only electronics!
I really don't think there is a problem with my figures. As I understand it, you need to take atmosphic pressure (around 14.5psi) off the MPA pressure to get the real boost pressure. I suspect your figures refer to the difference between MAP pressure and atmospheric pressure (boost pressure). Hence 30psi MAP is 15.5psi boost (the difference between MAP and atmospheric pressure). The ECU doesn't know the atmospheric pressure and reports MAP as the pressure inside the intake, but the real boost is the difference.That is my understanding of boost and was also the opinion of Thumper in a posting somewhere else on this forum.Bob
Hi!I am planning to buy this tuning box for my car.http://www.kcr.se/render_page_vs.asp?pageid=33&vehicleid=2194It is expensive, but they have 30 days money back if not satisfied, 2 years warranty and they have a 80.000 km engine warranty (in Sweden).Power increase: 140hp>160hp. Torque increase: 305Nm>355Nm.It is a lot of money, so i have not decided yet....Any suggestions?Cheers:SRT Metro
The tuning box Shambles uses (and is happy with) was about quarter of that I think..
I removed it for her second service tomorrow (I asked them to check for ECU upgrades, so didn't want the device *ahem* present). Makes such a difference to the drive with it disconnected. I collect her tomorrow after the 25K mile service.
Any upgrades I need to be aware of?If so, did it run any better than before?
Can i mount it on a brand new car with only 1500km on the speedo or should i wait a while before i mount it?
Quote from: SRT Metro on May 28, 2009, 22:02:58Power increase: 140hp>160hp. Torque increase: 305Nm>355Nm.thats a big power and Torque increase they claim. is this for a 2.0 CRDi?
