Reverse Osmosis Filter
Lakes · 11 · 2225
Anyone use one of these to filtrate there water?
No, requires a lot of effort for what you get, but better than dying of thirst. Are you intending to use one.  :question:
Offline Just Rick
  • Big Dogs Rule
      Beverley Western Australia
  • miracles can happen
was there meant to be a link here,what type of water you trying to filter and how much
Offline neptune
Coral Bay Caravan Park in WA runs reverse osmosis. They suck up water from a bore which is over a mile deep and need to run it thru the rev osmosis system before running it thru the parks water system. Give them a ring and they should be able to give you all the ins and outs of the system
Offline FatBoy
      Cygnet, Tasmania
Yes, I have used one before.  That is the way that warships get their fresh water.  Better quality than what you get in the town systems IMO.  But, and it is a big but, the Navy's system wasn't cheap to install, run or maintain.
It turned sea water into fresh water, depending on the ship I was on, made the difference between having a good supply or limited supply.  But this was more to do with storage of the water.  Oliver Hazard Perry Class FFGs could only store 25 tonnes of water, with a crew of around 220 (during peak operations), whereas the Anzac Class FFH could store 40 tonnes with a max crew of 180.  More storage, less people, less water stress.
thanks all, i am going to try a small unit just to filtrate drinking water, to eliminate flu ride & the the rest. see how it goes, not on the scale of the navy  :)
cheers
We use one of these from Kmart which works a lot better than these reviews! 3 x replacement filters only cost $18 and they last 3 months each  :goodjob:
Homemaker Table Top Water Chiller Water Filter Reviews Australia
or you can use one of these that I used to sell myself years ago ...
Stefani Water Filtration Ceramic Water Purifier 8L at .00 in Water Filters
there are various versions of these available  :goodjob:
Thanks Dazz i don't think those one's remove what i'm trying to eliminate.
I thought the Stefani one would!
No fluoride in my water!  :winker:
you got tank water?
that's the best, i drank some beautiful spring water in Tassie. the best must have been from Lake Skinner, good walk to get there too.
you got tank water?
Yep  :D (2 x 10,000 Gallon Concrete tanks = nearly 90,000 litres) :goodjob:
