I have a 09 diesel wagon its done 95thou Ks although it doesn't mention anything about replacing the drive-belt in the owners hand book I thought I would have a look and see whats involved but I couldn't see where any of the units the belt drives (power steering.air-con,alternator idle pulley)has any adjustment to allow enough slack to enable a replacement belt to go on.Any one done one.Cheers mitchell
Doesn't look too hardThere is hidden content here which only members can see. Please Login or Register.Just follow instruction 2The tensioner is the small pulley in the centre, it should be spring loaded, so the hex wrench needs to work against the spring tension, NOT ACTUALLY UNDO THE NUT !WATCH OUT FOR YOUR FINGERS, TOO.
Quote from: mitchell on March 09, 2014, 21:55:22 I have a 09 diesel wagon its done 95thou Ks although it doesn't mention anything about replacing the drive-belt in the owners hand book I thought I would have a look and see whats involved but I couldn't see where any of the units the belt drives (power steering.air-con,alternator idle pulley)has any adjustment to allow enough slack to enable a replacement belt to go on.Any one done one.Cheers mitchellIt is recommend to do the serpentine belt at the 105 thou k service,along with all three pulley's can get a set off of Ebay for around $160,I have gotten an individual price for the belt alone and that was quoted at $77
