DazzSince you are using a vintage PC with the performance of a slug I have typed this message slowly so you will be able to read it.
Nothing exceeds like excess. You would be about the only other person I know other of than my good self who takes backup seriously. What version of Acronis are you using? I'm still on True Image 2010.
Haven't yet found I need extra speed anywhere.
Quote from: Surferdude on March 29, 2014, 07:25:43Haven't yet found I need extra speed anywhere.Trev, if you decide you do want something a bit faster and don't want to spend a fortune, these are a cheap option and while nowhere near as fast as an ssd they are quite a bit faster than your standard run of the mill hard drive...Western Digital Veloci Raptor 160GB Sata 10000 RPM WD1600HLFS HDD | eBay
Woof
I've seen too many likelihoods of catastrophic failure and short lifespan to entertain SSD as viable yet, and my performance demands are very modest anyway, especially with a lean, efficient Linux.
Why do they fall over AK ?I thought the benefit of SSD was that defrag is unnecessary and allocation of data over the many sectors was a non physical thing, therefore more reliable.
Based on previews, the update will be smarter about the type of computer it's on. It'll boot directly to the Desktop on those computers that don't have touch screens.
Also, just to clarify, Mac OS X is not built on Linux, rather it inherits genes from BSD, and NeXT OS.
Quote from: Phil №❶ on March 30, 2014, 00:06:44 Why do they fall over AK ?I thought the benefit of SSD was that defrag is unnecessary and allocation of data over the many sectors was a non physical thing, therefore more reliable.Consumer class SSD's fail mostly due to faults in their controllers.Enterprise class SSD's in high write environments can fail due to high number of write cycles.However if the SSD is from the very early generations, they can fail due to reaching the write life cycle of the memory chip.Modern SSD's mitigate this by using TRIM, where the OS tells the SSD controller which blocks of data are no longer used, and can therefore be deleted.SSD's also use wear levelling, where an SSD uses additional unadvertised space on the drive to ensure that the write cycles are spread evenly across the memory chips so as not to excessively write data to particular cells, and therefore wear that memory cell out prematurely.For instance, a 256GB SSD may actually have another 20GB of space that is only available to the SSD controller.The very interesting thing about modern SSD's is that data, once deleted, is gone for good. It is no longer retrievable. This video from Defcon 21 is a great watch, explaining why/how in more detail.Defcon 21 - Data Evaporation from SSDs - YouTubeAlso, just to clarify, Mac OS X is not built on Linux, rather it inherits genes from BSD, and NeXT OS.
This is as good a place to document the last 2 days or so.Bought an HP laptop.2.3GHz4 GB RAM500 GB HD (5400 IIRC).Windows 8.1 So, I set out to try to understand what was happening as it came. Disn't want to screw up anything making changes too early.Most important things were.Get the mail client working as close to Windows Live Mail as possible. And link Claire's existing 2 e-mail addresses. Google is your friend - but still took some doing and interpreting the various guides, then modifying accordingly.Get rid of any unnecessary apps and place those we kept into a workable order. Learn how to relocate and resize. Set up Skype and Firefox and import bookmarks.Made good use of Dazz's Windows 8 Tips (many thanks Dazz )Finally, went to download that little program Alan Ho uses to change the appearance of the start screen.They wanted to charge me for it so I fished around and went with Classic Shell which is free and seems to do everything I wanted it to. Spent some time adding and removing the links I wanted off the Start Menu. Looking pretty good ATM.Most important thing has been to find a simple version of Solitaire. I've got one but it's not completely the same as that in WXP. It seems to have automated some of the moves whereas Claire preferred to carry them out herself. Work in progress. NOW!The big next step.Edumacate the regular user. I'll update here as the progress unfolds.
