i30 FD, Radio FW Update and starting from first file
sopel · 8 · 6509
Offline sopel
    • pl Poland
      Bytom, Poland
Wasn't here for sooooooooo long ;)
Ok, get to the point.
1. After so many years, did anyone find any FW update available anywhere?
2. My USB started to act crazy. Every time I turn my car off, and then start it again, the radio starts playing songs from the first one. It didn't happen earlier, now it started. I checked it on 2 different flash drives and it keeps doing that. The port isn't loose, I tried to moving flash drive all the way around, and it keeps playing. Anyone had similar problem?
P.S. Sorry for my "engrish" ;)
Offline Jarek
    • pl Poland
      Silesia
  • Greetings from Poland
 :welcomeback:
Hi Sopel (you are a very naughty boy - have you got a letter from Mummy and Daddy explaining your absence)  :TutTut:
But seriously, if it were me I would disconnect the negative terminal of you battery for 30 minutes which will reset everything and might fix the issue. Not sure if you will need to enter a security code afterwards though.  :undecided:
Offline PhireSideZA
  • French Diamond Driver
    • za South Africa
      Port Elizabeth
  • Phil her up!
Hmmm, I have that same issue of the radio playing the first song after it is turned off and on. Using an 8GB Verbatim store n go. My previous Transcend 16GB wouldn't pick up in the stereo. I'll check my firmware tomorrow and see what it says.
EDIT: I have V1.04.GEN
« Last Edit: June 07, 2014, 20:31:23 by wabbit16 »
Offline Jarek
    • pl Poland
      Silesia
My radio works perfectly  :cool:.  MP3 playback is resumed perfectly  :happydance:
Here's my device summary:
A-200FDE
SW:V1.07EUR
EEPROM:FD200E52
Offline timo111
      Australia
Offline PhireSideZA
    • za South Africa
      Port Elizabeth
  • Phil her up!
Where do you download the firmware updates from>?
I stand corrected but I think only the dealers can update the firmware
Offline Jarek
    • pl Poland
      Silesia
SW:V1.07EUR is my original version. Maybe it was updated during review by service? I don't know.
