AGM Batteries and ISG Information
AlanHo · 11 · 9511
I took my KIA Venga to my local KIA dealers today to complain that the ISG was not performing correctly. The problem was not the usual one that the engine was failing to stop when it should – quite the opposite, intermittently it would fail to start when the ISG had stopped the engine and I depressed the clutch.
The service manager was most attentive and we spent 40 minutes doing laps around their large site to test it out. I am sure you know what is coming – the ISG stopped the engine every time and started every time upon either depressing the clutch or operating the brake a second time. Hence he was not able to see the problem
He went through their standard ISG test procedure which included air con settings, rolling down a ramp with ISG operating to ensure the engine automatically started at 3 mph and stopping the car with ISG operating and measuring how long it took for the engine to start automatically. My car passed all the tests – as it would – because the vexing problem is intermittent.
The 40 minutes was well spent however – because I learned a bit more about ISG and the AGM battery.
ISG operation depends on various pre-requisites including the battery condition - no doors, boot or bonnet open - occupied seat belts buckled, car at standstill with foot off clutch (For manual cars gears in neutral), air con not running at maximum, no significant load on the electrics drawing power (eg : car Fridge in boot), etc. I can’t remember them all.
He roughly gauged the condition of the battery by the simple test of timing how long it took for the engine to start automatically after sitting at a standstill with ISG on. The longer this takes – the better the condition of the battery. My car took more than 2 minutes which indicated the battery was fine – had it have taken only 10 seconds then the battery would be the chief suspect. The longer the time the better the condition of the battery.
He was horrified to learn that I had twice recharged my battery in the car without disconnecting the terminals – even though I had used a proper AGM battery charger. He told me that the KIA instructions to dealers are clear.
•   You must first remove both battery terminals,
•   Connect the proper AGM charger
•   Charge the battery for at least 24 hours.
•   Remove charger and reconnect the battery terminals.
•   Leave the car for 4 hours for the AGM control module to learn  and teach the ECU the new battery condition.
•   Start engine and test the ISG.
•   Put back your radio setting etc
The AGM control module is inside a black box to the side of the positive battery terminal. It measures battery condition and current flow to and from the battery, constantly communicating with the ECU to control the ISG. I am told that this is a very sensitive unit, costs the thick end of £500 to replace and can be damaged by improper battery charging. Jump starting and battery charging without disconnecting the car terminals or the use of a proper AGM charger are an absolute no-no.  If the AGM Module is found damaged – it is generally because an owner has recharged the battery
Offline asathorny
  • Wonky Donkey
  • Curmudgeon
That was all very interesting Alan, even to dopes like me who don't have ISG....
Although I must say that from all I read here and in other places I am quite happy not to have ISG  :Shocked: :Shocked: :goodjob: :Shocked: :goodjob:
After reading that I'm glad i don't have ISG
That's an excellent resume :goodjob:
If you don't mind I'll move it to our Tech Data section :)
Offline Mike SX
      Essex
Wow. So many thing to go wrong.
BTW Alan, does this mean he's marked up your history so no claims allowable against the AGM Control Module?
No - I'm good - because the ISG was working faultlessly when he tested it and the battery was fine. If I had blitzed the AGM module the ISG would not actuate.
So if it take 2 minutes, then the battery is good. What's going to happen in London town, where the Diesel engine is supposed to be cut by ISG and it restarts, because of a poor battery condition.
Driver gets a fine.
     :foottap:  ££££££££££££
Thank's Alan, I've been useing AGM battery's since the 1990's, with Harley's with great results they out last anything else, seem to handle the vibration those motors put out (they are like a giant impacter ) especially the old ones I used to ride that did not have rubber isolation engine mounts or counter balances like the new ones today. I used C- Tec charger always had it charging with terminals on battery have never experienced a problem.
But there must be a good reason KIA say disconnect.
Thank's again for posting
