Hi Number9, have you had the car from new? It's not unheard of a timing belt jumping a tooth, it's just one of them thing's, it could be a failed tensioner, or not adjusted correctly, worn belt/ stretched but it does happen no matter what make of car you have.In the Hy servicing schedule there is provision's for inspection and replacing the belt that's if you've had Hy service your vehicle.And if I had a car for 6 years i would be quite happy if that is all you had go wrong with it, apart from the timing belt issue.Don't forget most of the parts on a car are manufactured from 3rd party suppliers.
Quote from: Johnno on April 30, 2015, 23:04:57Hi Number9, have you had the car from new? It's not unheard of a timing belt jumping a tooth, it's just one of them thing's, it could be a failed tensioner, or not adjusted correctly, worn belt/ stretched but it does happen no matter what make of car you have.In the Hy servicing schedule there is provision's for inspection and replacing the belt that's if you've had Hy service your vehicle.And if I had a car for 6 years i would be quite happy if that is all you had go wrong with it, apart from the timing belt issue.Don't forget most of the parts on a car are manufactured from 3rd party suppliers.Johnno, whilst that last statement is true, it hardly excuses the vehicle manufacturer who is ultimately responsible for the quality and reliability of the items sourced. If they aren't up to scratch, alternative suppliers should be sought.
If it were me it would be a new set of valves and a head job
I want to know why it's automatically a complete motor?If it were me it would be a new set of valves and a head job, check the Pistons but I'd bet there fine (a small dent at most) and put it back together.I doubt that would run half the cost quoted.Oh and of course diagnose and rectify cause of belt failure.
Never heard of a cam chain actually breaking before.
Must be a hoax, it won't start playing for me.
Couple of things going on there.Chain has stretched. No idea of age but to be stretched that much it must have done a lot of K's. (or the stock chain is rubbish)Hydraulic tensioner has a very poor spring. Spring is required until oil pressure gives the tensioner some grunt, but perhaps with that stretched chain the slack adjustment limit was reached?As a by-the-by, this is the reason one never forces a timing chain engine to rotate backwards. Tension is on the wrong side and the slack adjuster can't do its job.
