Whenever you set the direction to windscreen it defaults to A/C on for maximum defogging.
Quote from: cruiserfied on June 16, 2015, 10:43:29Whenever you set the direction to windscreen it defaults to A/C on for maximum defogging.Interesting. Haven't come across that before.
Quote from: Stuwoolf on June 16, 2015, 11:28:09Quote from: cruiserfied on June 16, 2015, 10:43:29Whenever you set the direction to windscreen it defaults to A/C on for maximum defogging.Interesting. Haven't come across that before.I've had a few other cars do that too, although I tend to set auto to off and adjust everything manually.
Quote from: Dazzler on June 17, 2015, 09:57:29Quote from: Stuwoolf on June 16, 2015, 11:28:09Quote from: cruiserfied on June 16, 2015, 10:43:29Whenever you set the direction to windscreen it defaults to A/C on for maximum defogging.Interesting. Haven't come across that before.I've had a few other cars do that too, although I tend to set auto to off and adjust everything manually.Can the "auto" be switched off? Would like that to be the case.They is MY buttons and I like to press em to come on........thankyouverymuch
It's like buying a dog, and then choosing to bark yourself.
The windscreen clears much quicker when the A/C is on, when it has done its job I switch the airflow to the cabin and sometimes turn A/C off. It has never bothered me.
