Where are you based? For European models there is a table in the owner manual which lists the preferred oil (Shell Helix) as well as other recommended brands.
Soon as I get around 500 Miles on the car, I'm most likely going with Mobil 1 5w30 and getting the factory fill oil out. There really isn't a "BEST" oil out there, as long as it meets specs it will be good to go. It just human nature to want that warm and fuzzy about what we use. Hell I get all warm and fuzzy about Mobil 1 so... At least it's a good oil.
What's the benefit of what? Changing at 500 miles or going with 5w40. I actually meant 5w40 in above post (ooops TYPO) If you mean 500 miles, then its to get all the early wear metals that come loose from moving engine parts out of the system.If you mean the Mobil 1 5w40, then its because it's a great quality oil that gives me the warm and fuzzy feeling. I've used Mobil oils for better part of my adult life, They've never let me down. Hope this helps.
@bensintic, I forgot to mention that if you can find a Blackwoods store near you Shell Ultra is about $44 through them ( nearly $70 in major auto retailer stores ), ring them first to check on stock and they'll order it if need be.
The change interval in my book says 10000 km. I know Hyundai has a deal with Shell, just not sure what they actually have. When you take cars in for service, they ask you if you want 5000k or 10000k oil. Meaning Dino or synthetic here. Fuel and petroleum stations are owned by the Government,(ADNOC is the name) but there are some specialty shops that are like a Jiffy lube type places and that's where I can get the oil I want or desire albeit it may have to be ordered in. There aren't any stores to just go buy oil here. I still have time so,,, Hyundai is particular about the services here. It really helps to sell a car second hand because of the service documentation. People want to know a vehicle has been serviced at proper times by dealerships here. 10000 km is 6213 miles and todays oils, Dino or Syn can go that distance plus, even in the temps reached here. This car is a GCC spec'd car so it has something going for it in these temps with it's enhancements. I guess I'll have to study on the Shell oils some since I don't know much about them. I've been brand loyal so long I'm sure some stuff has passed me by.
Quote from: CraigB on August 06, 2015, 07:15:23@bensintic, I forgot to mention that if you can find a Blackwoods store near you Shell Ultra is about $44 through them ( nearly $70 in major auto retailer stores ), ring them first to check on stock and they'll order it if need be.Thanks crigeb i got this oil
Quote from: bensintic on August 06, 2015, 10:51:34Quote from: CraigB on August 06, 2015, 07:15:23@bensintic, I forgot to mention that if you can find a Blackwoods store near you Shell Ultra is about $44 through them ( nearly $70 in major auto retailer stores ), ring them first to check on stock and they'll order it if need be.Thanks crigeb i got this oil Don't thank me, I didn't recommend that stuff, I hope that isn't the oil filter you purchased Hyundai wont warrant your engine using aftermarket oil filters...plus the K@N and Royal Purple oil filters are 25 micron - 10 micron is what is required.
