Roof Rack / Capacity - Kayak
dammit · 15 · 7817
Offline dammit
      Surry Hills, NSW
I am trying to find out the capacity of the i30 for roof rack. Is there a manufacturer imposed capacity, or is it up to the individual hardware/third party roof racks to specify this?
I checked the car manual but it doesn't list a roof capacity.
I am trying to find out if the car is equipped to carry my large kayak, which weighs 86kg (190lbs). The length of the kayak is 5.6m / 18'6". Don't know if this is way too big for such a small car?
I have a 5 door i30 2012 Trophy 2.0L if that helps!
  • i30 2012 Trophy
I'm pretty sure this question has been asked in the last few months by someone else. If I can find the thread I will post a link here.
My gut feeling is that it shouldn't be a problem, but don't sue me! :whistler:
Offline John B
  • John B /aka Sloop
      Gold Coast Qld
Here you go , had the same problem.:link: maximum roof load on 2014 GD hatch i30 petrol Includes Dazzler's input as well. :rofl: :rofl: and Wabbit showed actual illustrations to help. :rofl: :rofl:
« Last Edit: August 27, 2015, 07:19:51 by John B »
  • Toyota Kluger KXR AWD
Offline dammit
      Surry Hills, NSW
Ah cheers for that! 80kg... So I wonder if an extra 6kg is going to break the bank.....
I am actually a bit more concerned about the length. Seems 5.5m is very long with only a 1m "spread" between cross bars and a 4.5m car?
  • i30 2012 Trophy
Offline John B
  • John B /aka Sloop
      Gold Coast Qld
I would not think so weight wise. i expect there would be some safety margin in those figures. If it was me I would go for it but don't quote me. Not sure how you would go insurance wise though. Cant help you length wise as I am not sure of permitted o/hang.
86kg kayak :Shocked: is it made of wood :snigger:
My brother has a double ocean kayak and that's only 32kg
^I'm surprised by the weight too. Mine is a single, sit in, ocean kayak about 16 ft long and comes in just under 30 kegs.
The length is ok but I won't go driving down the highway at 110kph.
Fortunately up here on the Sunny Coast, there's plenty of nearby waterways.
Offline dammit
      Surry Hills, NSW
Yup 86kg's...its a sailing kayak. I managed to find a fellow with a similar set-up on an i30. He had a front steel bar mounted to the cross-member of his i30 to add extra support.
I'm not 100% confident a kayak of this size/weight could be safely carried on the i30 without the extra support, although technically it should be capable?
Hopefully he won't mind me showing you all his pic:
  • i30 2012 Trophy
If you have the front support bar as well then that would take a fair portion of the weight, you'd be good to go :goodjob2:
 :whsaid: Looks like it needs that bar for length more than weight!  :goodjob:
Offline FatBoy
      Cygnet, Tasmania
I wouldn't carry an 86 kg kayak on a set of bars with a weight limit of only 80 kg.  Your insurance would be void to begin with.  You haven't used the vehicle in accordance with manufacturers specifications.  Also, if an accident did occur, and somebody was injured, you would be up for costs, not the compulsory third party insurance.
Offline dammit
      Surry Hills, NSW
FatBoy - the book or specifications don't actually mention anything about the roof capacity though in Australia. We are only going off some info on a UK specifications to establish that....? From what I can see in Australia there are no specifications imposed by manufacturer (Hyundai) relating to roof rack capacity? It's not like trailer capacity which is clearly documented. Maybe I should email Hyundai asking them officially. Others have mentioned though that they under-estimate/err on the side of caution.
Obviously though I want to be safe and do the right thing, so would need to be 300% positive that it was stable, safe and correct. I can possibly remove some parts to get it to 80kg as opposed to 86kg for the roof. I would just need to ensure the roof rack bars I buy were rated to say 100kg or higher (which I think most are, even that weight rating per bar??) so it is over-engineered and extra safe/stable.
  • i30 2012 Trophy
Just checked Rola and they're only rated to 30 kg.
Rhino's are 75kg rated :link: Fit My Car | Rhino-Rack so if the front support bar can take another 20kg's to spread the load you would be fine.
Offline crayman
      Gympie
Just put Rola racks on Mr's car, rated at 30kg. (PER BAR)
But no way would I carry that big thing on i-30 racks, front supported or not.
The mounting bolts into the car's roof structure are puny, M6.
Get some windage from a passing truck or similar and that whole lot will rip right off the car.
In previous vehicles I've carried rowing sculls thousands of K's.
They're quite light and although they were all front bar and tow bar supported due to the length, every time a truck went passed I thought this time she's gone.
The racks BTW were much, much stronger than Rola racks.
  • i-30
