Cold start engine miss - Glow plugs or fuel issue ?
Offline DeathRattle
What would cause the car to misfire from a cold start ?
Been doing it for about a month and slowly getting worse.
Will do it for about 30 seconds.
Tried an experiment yesterday;
turned key on, waited for glow plug to shut down, turned key off,
Did this maybe five times.
Started car, perfect idle, drove off, gf said (she drives, not me) hasn't run this good for ages.
Glow plug seems to be running for 1 second before turning off.
Theory,
Either the glows are not running for long enough (temp sensor or timer issue ?)
Or the fuel system is not providing the right pressure (filter or pump issue ?)
Any thoughts before I take it in for warranty ?????????????????
sounds like she needs a new fuel filter.how many kms have you got on the car.
i dint know at what duration of distance or time your filter needs changing as my cars are petrol i30s,but i do work with diesel engines at work[i make fire pumps] some one like dazz who owns a crdi may know when a fuel filter needs doing.water is another thing it might be.  :eek:
Offline LuciferDarklord
      Bindoon, W.A.
  • Bindoon, Western Australia.
Could be air as well, might be worth trying to bleed the whole system.
Fuel filter is down for replacement at 3 years or 37,500 miles in mine, but you don't have "miles" down there do you :P
so about 50,000 kms.
Offline DeathRattle
was wondering if its anything to do with the filters that have the 3,000 rpm limit bug on them......
Bit of an odd one DR??
  • Midlands, UK N-Line T-GDi
Offline Merlot
      Hunter Valley
Hey Shambles yea mate we have miles down here just call them kilometres now
Offline DeathRattle
Just trying to get a better understanding of how things work, being our first diesel etc.
When i have the time I'll take it in and see what they say...
      Bindoon, W.A.
If its a fuel supply problem or air in the fuel, it will not be a 'miss' as such, more like a rough idle and hesitation / surging.  If its a glow plug (has anyone actually confirmed there are individual glow plugs in the 1.6lt?) then it will only 'miss' on that particular cylinder.  It will sound similar to a petrol 4cyl when one spark plug lead is removed.  Normally you would expect some whitish smoke too as the fuel is not burning in that cylinder.  Another thing it could be, if its only one cylinder, is a sticky valve or sticky injector.  I'd get it looked at straight away as some of those issues could lead to further problems downstream from the problem, and they may baulk at warranty if you havent had it looked at straight away.  Play safe, take it straight to the dealer.
Offline DeathRattle
Hmmm, true.
Do have an rdo or three owing so will try and organise asap.
Will keep you all informed......
ouri30
...  If its a glow plug (has anyone actually confirmed there are individual glow plugs in the 1.6lt?) then it will only 'miss' on that particular cylinder.
From what I understand, there is a single preheater (like a large glow plug I guess) in the air intake.  It simply heats the air so that the first burst of air into the cylinders is warm and aids ignition.  This was written about in an posting some time ago.
Bob
      Bindoon, W.A.
Yeah I thought that was the case - but I couldnt see any fat wires going to the inlet manifold anywhere (normally they draw a fair bit of current those preheaters)  Another post said that the dealer replaced one of his glow plugs and they have individual ones in each combustion chamber, however I didnt see the usual 'buzbar' that feeds current to them all, being 4 valve and injector in the center doesnt leave much room for a glowplug.  All hearsay really until I see a pic or a Hyundai service tech can confirm.  DI engines do not need a glow plug to start generally, thats why i'm a little concerned for DeathRattle coz really it shouldnt miss just because of a faulty glow plug...  but once again i'm just shooting off the hip here coz I really dont know the ins and outs of this engine.  If I start ripping stuff off my missus will have my nurries in the vice!
Sorry to hear about your problem.
my i30 has always started easy, i don't think it uses glow plugs, because the diesel trucks at work have glow plugs and the light on them goes off that fast, you have to be looking or don't see the warm up light. the old glow plugs on truck's took longer to warm up but the truck's ten years or newer have very fast warm up time. thats why i don't think the i30 uses glow plugs more likley as Bob ( ouri30 ) states a intake manifold heater, as my i30 takes a few seconds to go off but i always wait for it to go out before starting.i don't know if it would matter just with the old slow warm up glow plugs if you kept starting a diesel with them before the light went out they would burn out then you had no glow plug. then you have to use Eather to start them ( more trouble )
hope you find the problem.
cheers
I think our i30s have glow plugs, fuel filter and air inlet heater
See the fuse gauge chart...
lindlake
yes they do have glow plugs i pull off the cover and had a look
Online eye30
Glow plug light has to go out before you kick the starter motor otherwise it will not always fire up.
Be patient and wait until the light goes out.
In cooler weather mine takes slightly longer to go out.
I'm sure I'm not alone.  I just hop in and start the car and it fires immediately. Either the glow plugs are not critical in temperate climates or they heat sufficiently while engine is cranking anyway.
      Bindoon, W.A.
As I've said before, Direct Injection engines do not need glow plugs to start in above-freezing conditions.  The surface area of the combustion chamber is so small as the compression ratio is high, very little heat is lost to the engine from the air being compressed.  My understanding is that are only for emmision control and very cold climates.  Thats exactly the reason it worries me that DeathRattle has this problem as I cant see it being caused by a faulty glow plug.
Interesting, could you see them just by pulling off the main engine cover or did you remove the valve cover?  Any pics?
Yeah .. me too  :-[
lindlake
yes i just pulled off the cover only two bolts the glow plugs are near the turbo manfold? my i30 needs the glow plugs every time if not it takes about 5 seconds to start
[deleted]
just make sure you wait till glow plug light goes out, b4 starting as eventualy you burn out the glow plugs. i have started mine fast without looking at glow plug light. but always look at light now. as takes a while to go out. but mine has never had a problem starting.
      Bindoon, W.A.
Thanks Lindlake, that clears that one up!  What sort of temps are you in to notice difficult starting without 'glow time'?
      Bindoon, W.A.
OK thats pretty mild, I've had a few minus 2 DegC mornings here, but I habitually glow my engine before starting.  I know the older Direct Injection engines I'm used to working with are a little higher compression ratio than the i30, so maybe when the temp gets low the i30 does need a glow plug to prevent any missing.
