Light brown sludge in engine coolant
chrisnka · 47 · 15716
0 Members and 16 Guests are viewing this topic.
Offline chrisnka
      Huddersfield
Hi all,
Just come across this today on my 09 comfort crdi 1.6 anyone had this before or has previous owner tried to cover up a fault?
Chris
Sent from my SM-N910F using Tapatalk
  • 2009 Hyundai i30 1.6 Comfort CRDI
Sounds like it didn't get the coolant changed as per schedule!  :Shocked:
Offline chrisnka
      Huddersfield
Not a good sign IMHO!  :disapp:
Offline chrisnka
      Huddersfield
Do you think the best thing to do is get it flushed?
Offline chrisnka
      Huddersfield
Still covered under our 3 months warranty, or do you think it would be best getting our money back?
Might be ok, but I would get an independent inspection by a friendly mechanic.
If you decide to keep it,  I would get it flushed. Hopefully it doesn't have a blown head gasket!  :undecided:
Looks almost like oil in the water...
Offline chrisnka
      Huddersfield
It is OK on engine temperature, we travelled from Yorkshire to Scotland on Monday and all seemed ok.
Offline chrisnka
      Huddersfield
Right ok, think we will take it to a garage when we get back, would head gasket normally be covered under a warranty?
Have you got a full service record? It should be as long as they don't try and pin it on you.
Bit hard to diagnose from 12,000 miles away.  :cool:
Offline chrisnka
      Huddersfield
It has full hyundai service history apart from the last one which was done by the local garage we bought it from. I think I will get my mate who is a mechanic to have a look when we get back. It does have a slight smell of exhaust gases(I think)
I am no mechanic/technician but over the last 50/60 years have been obliged to get stuck in a do my own car work more often than I would have liked....
Based upon that limited experience I would instantly suspect contamination either from a leaky head gasket, or from somewhere else???
If you flush the cooling system you'll be flushing away the evidence.
I would take it back, sooner than later.
good luck  :goodjob: :goodjob:
That can be a sign of a leaking head gasķet...
Offline chrisnka
      Huddersfield
We will be taking it back next Monday when we are back. Thanks for the advise guys. I'll be keeping an eye on the temperature gauge until we are back
Offline chrisnka
      Huddersfield
There's no signs of oil around the engine bay or near the headgasket that I can see, obviously doesn't mean there isn't an issue there though
Good luck with it anyway. Bit of a worry, but may be ok.
Offline chrisnka
      Huddersfield
Thanks, just another obsticle to overcome. Will let you know how we get on when we get back home next week
:goodjob:
Offline diesel1984
Looks like someone mixed green with pink or red coolant. You will need to clean this mess and put right stuff in.
Your car takes green type coolant.
  • 1.6crdi
Remove the engine oil filler cap.
Is the underside of the cap just oil or is it whiteish sort of gunge?
The latter i think may show signs of gasket failure.
Also, what colour is the end of the exhaust pipe?
Depending on this colour it may indicate engine issues
Just another thought.
If the cap has failed, i.e. presure failure, then it will leak and on drying leave that mess.
Offline chrisnka
      Huddersfield
The end of the oil cap is just oil as I checked earlier. I will check the exhaust when I get back to the car and let you know
The mystery deepens....   can't wait to find out what's caused it  :head_knock: :head_knock:
Offline chrisnka
      Huddersfield
The rubber seal did look a bit worn but there's no sign of it leaking out of the cap area. Will be back at the car in a couple of hours
If it is just poor service (mixed wrong coolants etc) I would ask the dealer to do a flush and use right coolant. If it is oil that is mixed with coolant, I would want my money back.
Have you dipped your finger and tested how slippy it is ???   just a thought  :scared: :scared: :scared:
Offline chrisnka
      Huddersfield
End of exhaust is black on inside as I would expect, fine on the outside.
Offline chrisnka
      Huddersfield
It is slippy :(
It is slippy :(
Oops  :fum: :fum: :fum:
Offline PhireSideZA
  • French Diamond Driver
    • za South Africa
      Port Elizabeth
  • Phil her up!
What does the sludge smell like? Oil should have a distinct smell. That looks a lot like a car I once saw where the owner neglected to use antifreeze with brackish tapwater. A few months down the line it looked almost exactly like yours does
