Faark - glow plug broken or thread damaged
Asterix · 52 · 18285
Offline tla
Sincere commiserations!
Did they mention what is the recommended thread lubricant when changing the plugs?
 :faint: Oh no, such a good record till now, too.
Sorry to hear. :fum:
I'd be looking at other options if possible.
Offline Paolo5
I wonder why they 'welded themselves in' like that in 100K....I would have thought that you were doing the right thing by putting the copper grease on the threads when you installed them.  :crazy1:
Just guessing, but towing a van regularly and references to engine getting hotter than normal may have caused this phenomenon.  :question:
Offline Paolo5
Makes you wonder if the glow plugs should be removed periodically to make sure they do not seize up.
I have ordered some Febi ceramic grease and will do just that.
Never heard that the plugs could be stuck so hard that even machine shop could not drill them out. But I guess that is possible...
Did you use torque wrench when you changed them last time? Did you change them previously with hot or cold engine? I would guess they could come out easier with hot block, but at least in the factory they are put in a cold engine.
I hope it all goes well and the bill would be smaller.
I was planning to change my plugs for just in case, but I started really doubt if it worth the risk. My car has done 107tkm with original plugs.
« Last Edit: June 16, 2016, 19:40:40 by sundiz »
That's a job I'd get the dealer to do. They break something, they fix it.
Bugger.
Bit of a shame they wouldn't try drilling them out. An engine remanufacturing shop should have drill presses to get it pretty spot on, and if it came to heli-coils they are pretty bloody good. I have had seized exhaust studs cut out, new alloy welded in place, then drilled and retapped before.
Hopefully they go easy on you when the bill comes. Did they price a new bare head?
whats the cost of a second hand engine? Over here you can get an engine with 53k on it for $1700.
I don't know what they would cost to install though.
I believe I can get a similar used one for around the same price, but on top of the already spend hours, they would have to remove the rest of the engine and install the new one. Wouldn't end up cheaper at all.
Had I known the extent of this operation at start, I would have considered that option.
« Last Edit: June 16, 2016, 19:33:02 by Asterix »
Far out brussell sprout! That is a terrible outcome Henning. Had you known that I guess you may have attempted to do it yourself.  :undecided: :blubber:
No, I only have an open carport and handtools, so not an option, unfortunately.
Sorry to hear that.  :disapp:  Makes you wonder if the glow plugs should be removed periodically to make sure they do not seize up.
Have had that exact thought, but I bet I would shake all over when I have to loosen that first glow plug in 3 or 6 month time....  :confused:
Thanks. Haven't asked yet, but must remember to ask if any special lubricant is recommended in the workshop manual or from a TSB.
I have no idea and like you I thought I did the right thing.
I'm not sure all dealers share that opinion.... :(  ... but if you're right I could have had a lot of glow plugs changed for what this will cost me...  :(
Bugger.
Yes, but I think it's only fair they say no thank if they're sure they can create a perfect result.
Did talk to a colleague who have had same issue with a Land Rover, he had it machined out at a engine remanufacturing shop. I rang them to hear the cost, but it would be nearly the same as I have to pay for that used head the dealer have ordered, so didn't go for that option.
Offline Paolo5
The disaster that has occurred in your car, Henning.... has led me to do lots of reading about glow plugs and faults and problems that people have experienced...and to start a different (yet related glow plug thread):-
:link: Glow plug reamer availability
(that I perhaps started in the wrong section).
I hope that your i30 will be returned to fine fettle for just a modest fee!
It is strange but the only other diesel vehicle that I have owned was a 1980 Datsun Patrol that STILL has the original glow plugs fitted to it to this day! I wonder if any i30 owners will be able to say this in 2045!
Offline diesel1984
NEVER put copper or any other grease on glow plug threads specially on engines with aluminium head. The OEM install doesn't have any grease.
Grease can go on heads with non alu material threads/head.
OLD mechanics and new engines NO NO NO.
NEVER buy cheap glow plugs with cheap chrome and fragile parts. This engine have NGK original plugs so always buy this one only.
Tighten always with torque wrench 8Nm.
Before loosing spray with penetrating oil or ATF mix fluid few days.. NOT with wd 40, he is not for this kind of job.
Remove with hot engine, install at cold.
Follow these steps and you will never have any problems of this kind. :goodjob:
  • 1.6crdi
Got the car back today, will be so nice to drive my i30 again...  :D
There's oil in the coolant reservoir, that shouldn't be there after a head removal. Will have a talk to the workshop tomorrow, but might wait with too aggressive complaints until I receive the invoice... :confused:
Had a 2004 Getz CRDi as a loaner, what a piece of crap. Only 150.000 km on the odo, but terrible to drive. Suspension horrible soft, seating position not suitable for my 182 cm, and a lot of other things, mainly due to poor maintenance.
Here's what it looks like, would any of you know if the Bardahl flush additive is worth using... :question:  (I've had it for 6-10 years, so maybe too old now.. :question:)
I wouldn't be getting rid of the evidence yet, Henning. Wise move to wait on the bill 1st!  :sweating:
Let the dealer flush it.  :exclaim:
Offline Paolo5
It would be great to know what additive they put in....and why...
No additive like that is recommended by Hy in Australia.
Did they give you an idea of why the glow plugs weren't able to be extracted...or any ideas on how to prevent this from recurring?
Offline william
      Victoria
Wanted to change the glow plugs.
Bet you wished you had left well alone now!
Not really, it was needed...
:link: i30 startup - YouTube
That's nothing compared to the Ute i drive I've ordered glow plugs though, the amount of smoke it's embarrassing!
  • i30 wagon 09
