'ENGINE WATCHDOG' Overheating alarm-Engine/Auto trans.
jwhjwb · 4 · 2550
Offline jwhjwb
      Redbank, Qld
2011 FD CW 2L petrol & Auto Trans.  Am considering fitting an " Engine Watchdog" temperature overheat warning alarm.  Has anybody any experience with these units.  The T4 Unit I am considering is a dual unit, monitors motor and auto trans.  Any comments appreciated re
 Reviewing the unit:
 Where to fit the unit on/under the dash:
 If worthwhile monitoring the auto trans temperature:
 Most practical hard-wire point to use that is on/off via the ignition (eg. rear of lighter socket)
 There is now a T1 Unit which super-cedes the still available T2 Unit - both only monitor the Engine Temp.
FIY:  I have just completed fitting reversing sensors (a cheap kit) & working well.  Difficult but not difficult if I had to do another on a similar veh.
Send me a PM if you need to talk by phone.
« Last Edit: November 08, 2016, 06:50:58 by Phil №❶ »
  • MY 11 FD CW Wagon 2.0L petrol Silver
Why the need to monitor it any better than the standard system does? are you going to use it for a lot of towing?
You might also find a cheap OB11 plugin app that might provide the same functions :undecided:
I wouldn't be placing personal phone numbers on an open forum either :eek:
EDIT! I see Phil removed the number :goodjob:
« Last Edit: November 08, 2016, 06:54:59 by CraigB »
I'm repeating Craig's sentiments, why reinvent the wheel?
The ECU is already monitoring various temperatures and you have the best overall device right in front of you... a coolant temperature Gauge.
If there is one device I would add to the i30, its an oil pressure gauge. Old school, but gives a lot of info if the car is doing heavy work or has been mistreated.
