Stereo issue/ lack of understanding
i30joe · 4 · 1725
Offline i30joe
      Jarrow
Hi all I have an i30 fd 2011 model.
Basically there is a slot and menu for usb.
When I load music onto a usb stick. It doesn't display on the stereo. If it does I'm only able to listen to individual tracks from one album.
Is there a certain file path I need to create to make it so I can listen to multiple albums.
Thanks in advance.
Joe
Sent from my SM-G900F using Tapatalk
  • 2011 i30 crdi comfort
Offline ibrokeit
  • Author of War & Peace
Hi Joe
Sorry for slow response. Regards to filepath - not so far as I know.  However...
The first USB stick I used, it turns out, actually presented itself as more than one device.  In my case it caused the radio to forget which and where it was up to playing when turned off - starting from the start again.
Maybe it is something similar/same?
From memory the first one I used presented itself as a CD-ROM drive (of small size - used to hold 'helper' software from manufacturer and have it autorun) and then a mass media device (both connected via. a virtual USB hub).  The radio would ignore the 'CD' drive and find and play the music on the second drive - but not remember where it was up to (I assume that was a bug or bad program design).
That happens a lot with repurposed corporate gift USBs  :D
Offline i30joe
      Jarrow
I kind of sorted it I had to change the format of the usb which was a farce but even then only uses my 10-15 of the albums
