2013 I30 Tourer Handbrake adjustment
Offline woodyWoo50
      Dartford
  • I Love my I30
Hi Guys . I have just replaced the rear brake pads on my 2013 I30 Tourer and now the handbrake leaver comes all the way up (8 Notches). Any ideas how to adjust the handbrake ?. Any help would be appreciated,
Thanks Again
  • Hyundai i30 Tourer 2013
 :welcumwagon:
Hopefully one of our clever techie types will be along shortly...
Offline woodyWoo50
      Dartford
  • I Love my I30
Offline cruiserfied
  • Crooked-H Hero
2013 would be a GD.
Is your handbrake a lever or electronic?
GD handbrake is part of the caliper and doesnt really have adjustment. Only place is the cable under your centre console.
If its electric handbrake you need to retract and reactivate the handbrake via scan tool before and after pad change or else you will damage the calipers.
I assume you have already driven the vehicle, pumped the pedal up? Why were you doing rear pads on a 2013, heaps of km's?
Offline woodyWoo50
      Dartford
  • I Love my I30
Hi Ya. Its got a normal hand brake (not electronic) . The car has done 60,000 miles and the rear pads had worn out so i had to replace them. i replaced them yesterday no problem , But now the handbrake leaver pulls all the way up!!. So i assume that i will have to adjust the handbrake . I cant seem to find advice anywhere how to do this .  Please help me.
Offline woodyWoo50
      Dartford
  • I Love my I30
Offline woodyWoo50
      Dartford
  • I Love my I30
So how do i adjust it under the console? & how do i take the console out?
Original body shape is FD. Update is GD.
Removing the fabric bottom in the centre armrest will reveal an adjustment ratchet. :victory:
Offline woodyWoo50
      Dartford
  • I Love my I30
Hi There.
Thanks so very much for this information . you have made my life so much easier .
Thanks again. :) :goodjob:
Offline woodyWoo50
      Dartford
  • I Love my I30
Hi.
Thanks again , is it quite easy to adjust the handbrake via the ratchet?. Do i need any special tools or anything , or just a spanner?
This should help. I didn't know 3 minutes ago, but you asked and I Googled.
:link: Adjusting handbrake ? logbook Hyundai i30 | DRIVE2
Offline woodyWoo50
      Dartford
  • I Love my I30
Thanks so much , thats perfect. You have made my day. thanks again.
 :) :goodjob2:
Offline woodyWoo50
      Dartford
  • I Love my I30
How did you find info like that, I have been trying for 2 days to find simple stuff like that?
Simply typing "Hyundai i30 Handbrake adjustment" gives plenty of hits, a search of the forum provides some more :)
Offline woodyWoo50
      Dartford
  • I Love my I30
ok thanks , you are really kind.Thanks again.
What does "GD" mean?
GD is the series two shape . Which yours would be.
So basically what Tim is saying is you will have to adjust the cable under the centre console.
Offline yodm
    • il Israel
      Israel
you should get a 12 mm ratchet spanner.
I tried to do it with a normal 12 mm spanner and it takes a very long time as you can rotate the nut only very little each time.
  • I30 CW 2010 1.6 petrol auto
Offline cruiserfied
  • Crooked-H Hero
Don't go crazy adjusting the cable. Its supposed to have some slack when handbrake is off. If you adjust the cable too far it will cause dramas.
You really shouldn't have needed to adjust the handbrake at all. Once you have pumped the pedal to push the caliper pistons back out it should be right, self adjusting.
My concern is the piston may not have been pushed in properly and handbrake part of caliper is damaged.
If you adjust the cable under the console and find that there is no slack with handbrake off there is a problem with a caliper.
Loading...
