Right dipped beam no power
Offline Fr Dougal
    • ie Ireland, Republic of
      Dublin
Hi all, hope I am posting this in the right place..
My wife's car is a 2010 i30 diesel CW estate.
The right dipped beam has stopped working. Left dipped beam is working and all parking lights and high beams are working.
I tried two replacement H7 bulbs, no joy.
So I tried a multimeter across the connection block for the bulb and got no power. The connector block from the loom is clean, no corrosion and is fully pushed in so no idea what to check next. Any ideas?
Thanks in advance.
  • i30 CW
Hi Fr Dougal
 :wttc:
Have you checked the fuse..?
Offline Fr Dougal
      Dublin
Hi Fr Dougal
 :wttc:
Thanks for the welcome Asterix.
No, I didn't check fuses cos I assumed the one fuse would serve both dipped beams and one is working, is that not the case?
  • i30 CW
Hmm, just checked. You're right. It's the tail lights that have a fuse for each side... forget my rubbish advice.. :mrgreen:
Offline asathorny
  • Wonky Donkey
  • Curmudgeon
 :welcome: I'll alert our Tech support guys to this thread (they are all in Aus, so may not be on line yet..)
@cruiserfied @nzenigma @tw2005
Offline Fr Dougal
      Dublin
You are actually right. I found a fuse blown in the fuse box under the bonnet beside the battery. I replaced the fuse, it didn't blow again but the dipped beam is still not working
:wttc:
Thanks a mil for the welcome.
  • i30 CW
Welcome mate,
You found a burnt fuse.  That is probably your best clue. They blow for a reason! Which one was it?
On FD models, go to fuse/relay box next to battery. fuses 16 & 17 are Left & Right low beam, fuse 18 is common high beam.
If no luck with fuse changes, meter the relevant fuse for 12v (both sides.)
If you have 12v but no headlight, remove fuse and measure for continuity from cold side of fuse ( =0 volts) to the bulb connector.
If you get an open circuit reading, the break will be in the loom.
You may also have, or have had in the past, a wire shorted. Therefore, the fuse blows, but the short may have damaged the wire or a connector.
Its a fairly simple circuit, so good luck.  :)
also, especially check the fuse holder lugs. They may be burnt. WD40 them
Offline Fr Dougal
      Dublin
Welcome mate,
Thanks for the advice folks.
It's 2am in Dublin, quite a few beers have been taken. More investigations tomorrow, I will report back.
  • i30 CW
 :) My Irish kinfolk claim they did their best work at 2am.
Offline Fr Dougal
      Dublin
Hi all. Sorry for the delay replying. I am trying to figure out how to attach a photo.
So behind each headlight I found a strange addition. I can only guess these are to increase resistance to prevent headlights from blowing?
I have removed them and lights are working fine....
  • i30 CW
Offline Fr Dougal
      Dublin
Sorry @Fr Dougal I can't see any pics.
Try using a free hosting system like imgur:
:link: Uploading photos using IMGUR.COM
Sounds like you may have had an earthing mod done to reduce the incidence of blown globes (but it wasn't done correctly?)
Offline Fr Dougal
      Dublin
Hopefully this image link will work....
They both looked like the one on the left, the one on the right is when I removed the outer tubing which was wrapped in insulation tape
  • i30 CW
Hi,
Dazz is correct, the mod ( the yellow wire) has enough impedance to reduce any high voltage ' spikes'.
I cant see whether it is on the hot or earth side, but we can assume that a soldered joint has failed.
Hopefully with good quality bulbs fitted, you will not have the failures that the previous owner was trying to over come.
Thanks for taking the time to solve the problem and post the results.  :goodjob:
