HOW TO: Upgrade GD-03 head unit to current release with Android Auto support
bagerlk · 27 · 28712
Offline bagerlk
      Queensland
The GD-03 (i30), AD-01 (Elantra), DM-01 (Santa Fe) and TL-01 (Tucson) all now officially support Android Auto in addition to Apple Car Play via means of a firmware/software update.
To check if you need the update, follow the below
From your vehicles head unit, Press Setup then tap/touch System then Device Information and check the versions of the firmware/software currently installed. If your versions are lower than than the following then you are in need of the update:
SW Ver: 2.04.02
Micom: 3.27.00
Platform: 1.76.00
This is a free update however dealers may charge you a fee in order to have it installed in your vehicles head unit. You can however do this yourself and it is quite easy. The update files and full instructions are available freely on the cartronics website who are the manufacturers of the GD-03 (i30), AD-01 (Elantra), DM-01 (Santa Fe) and TL-01 (Tucson) head units.
Full Installation Instructions available here - http://www.cartronics.net.au/uploads/documents/update.pdf (pdf, 3.65Mb)
Firmware/Software Download available here - http://www.cartronics.net.au/uploads/firmware_files/1473034905_Firmware (rtf, 2Kb)
Note: The Firmware/Software Download URL links to a document on the cartronics website with an additional URL on how to obtain the download file from Dropbox. This is the official method of obtaining the instructions and download files direct from the manufacturer.
« Last Edit: October 30, 2017, 08:22:33 by bagerlk »
  • 2016 Hyundai i30
 :welcumwagon: Thank you very much, an excellent and extremely helpful first post.
Are you from a Hyundai Dealer, Cartronics employee or just a helpful fellow owner.
 :hatoff: :drinks:
 :welly3:
Google will provide an abbreviated URL if you want it. :goodjob:
Offline bagerlk
      Queensland
I'm just a fellow i30 owner who spent a few hours researching how to update my head unit and wanted to share what I found ;o)
  • 2016 Hyundai i30
One or two members tried this upgrade manually, with great success :)
:link: GD4 i30 Android Auto
Thanks for the links.
Offline i30dis
      NSW
So the links to download the firmware files no longer work (the dropbox links).  Does anyone know wear else you can get them?  of have a copy?
  • 2016 i30
Offline alancramer
      Australia, Adelaide
You want to download the file from the dropbox link in this new document.
http://www.cartronics.net.au/uploads/firmware_files/1504680387_Firmware%20Instruction%20and%20Download%20Link_HA_D-Audio2.04.02_and%20M_version.rtf
The firmware is a little newer than described in the help document (and above):
SW Ver: 2.04.07
Micom: 3.28.00
Platform: 1.76.00
  • 2015 i30 Active GD 5 Door Hatch, Petrol 1.8lt, Auto, White
SW Ver: 2.04.07
Micom: 3.28.00
Platform: 1.76.00
Thanks :hatoff: downloading the file now so will test it, odd that cartronics haven't updated the version numbers in the install instuctions :rolleyes:
All installed, works perfectly :happydance:
« Last Edit: January 11, 2018, 12:28:30 by CraigB »
SW Ver: 2.04.07
Micom: 3.28.00
Platform: 1.76.00
 :victory:
Offline lzancan
    • nz New Zealand
      Auckland
Hello everyone
does anyone have the updated link for the software update? cheers to all!
  • i30 2015 wagon
Offline aanastasiou4
    • cy Cyprus
Hello everyone
Here you go!
There is hidden content here which only members can see. Please Login or Register.
  • Hyundai i30 2012
Offline MartinL
      NSW
I tried following your advice to download a Firmware update for the GD-03 unfortunately this is what resulted.
Not FoundThe requested URL /uploads/firmware_files/1473034905_Firmware%20Instruction%20and%20Download%20Link_HA_D-Audio2.04.02.rtf was not found on this server.
I don't suppose you have a correct copy you can post up.?
Thanks in  advance for any help you can provide.
  • 2014 Hyundai i30 Wagon
    • cy Cyprus
Try this!
https://mega.nz/#!4VNS1CBC!TDtyBj-i0walRinImFxvqR2U9YLgyPwrU5hdx96FhMM
  • Hyundai i30 2012
Thanks in  advance for any help you can provide.[/font]
As aanastasiou4 has shown the mega.nz link is still live, cartronic's don't keep downloads live for much longer than a week.
You can also have it installed at any Hyundai service centre for free.
Offline goranoh
Can I install this update on my  Vehicle GD3 I30 HATCH 1.8P ACTIVE X MAN thank you.
« Last Edit: August 08, 2019, 05:28:08 by goranoh »
Sorry mate, as the pic shows you have a GD-02 so it’s incompatible with the firmware discussed here.
Offline goranoh
Try this!
This is the last update?
:link: MEGA
Yes it’s the last update for GD-03 units, as mentioned earlier you have the GD-02 which is incompatible with this firmware.
Offline goranoh
:link: MEGA
Yes but I ordered GD03 I will receive probably tomorrow and I after that I will arrange with you.
Offline Snapkop
      Western Australia
Hi, Know this is a old thread but any chance this will work on a 2015 HYUNDAI SANTA FE ELITE CRDI (4X4) DM SERIES II (DM3)?
Just did this on my i30 and worked great. However cannot establish what head unit the Santa fe has got. Is that DM or DM3?
  • 2016 HYUNDAI i30 ACTIVE GD4 SERIES 2
I wouldn't have a clue :Dunno: not many Santa Fe owners here...cant say I've seen anyone discuss the head unit either :undecided:
A Elite model Santa Fe would have a navigation system as well wouldn't it? if so it's definitely not compatible.
« Last Edit: February 09, 2020, 13:26:39 by CraigB »
Offline Snapkop
      Western Australia
Yes, it has navigation. Thought there might be a slight chance sobs the last time I checked on this.
I expected it so, sorry to spoil your day :(
For this update to work the unit has to firstly be an Australian Cartronics built unit without navigation.
