How to check if the HYUNDAI I30 1.6L CRDI DIESEL GLOW PLUG are working ?
Offline NATHAN_P
    • il Israel
How to check if all the HYUNDAI I30  1.6 CRDI DIESEL GLOW PLUG are working ?
Disconnect and check resistance and how many ohms ? :)
« Last Edit: April 03, 2017, 08:04:32 by NATHAN_P »
  • 2013 5 Door Inspire, Petrol 1.6lt, Auto, Metallic Gray
manual quotes
Check the continuity between the terminal and body as illustrated. Replace if discontinuity or with large resistance.
Standard value : 0.25Ω
depending on how good your meter is but allow for the lead resistance
Offline NATHAN_P
    • il Israel
Sorry illustrated where?
well I was copy and pasting the text so I did not put the image up. You would disconnect the power bar from the glows and then terminal post to the base of the plug would be the resistance.
How about  a nice video.  Can't comment on th evalues he's quoting , just the method.
Oh, and these can seize in the head and break off if you're considering removing them.
