SOLVED: ESC light on at 50 mph - every time - help needed
charlie8 · 91 · 51214
Offline charlie8
A set of issues been bugging me if any one can help
ESC light comes on on every drive cycle at at 50 mph - stays lit. Turn car off/on it resets, then 50 mph again
Start/stop does not work
Cruise control won't engage
On gear change, revs seem to drop dramatically almost lurches
ODBII reader - no codes
I have tried - checking all wheel sensors/cleaned. All rotor teeth seem present
Brake light come on OK - so switch is good ?
Dealer wants £96 to read the code - thats a 5 min job - so I am fighting all logic to work out whats wrong than pay anyone who thinks thats acceptable price
If a wheel sensor, ABS light shoudl be on too
Throttle pos sensor would show hunting revs or instability - it does not
If I stamp on brakes - ABS works. If I try and wheel spin ESC light flashes. So  that seems good
ANy clues ?
« Last Edit: September 30, 2017, 12:05:11 by charlie8 »
  • i30
ANy clues ?
FD Series.?
I thought there was a recall for defective brake switch for ESC light coming on? Free fix
My hatch had the ESC coming on and staying lit, clearing after restart and randomly coming on. Had Free replace as it's a known defect and recall over here at least. I'd expect the same all over the world but the problem has not come back since.
Dealer should be able to check if th ework has been done via vin. Contact Hyundai and check? Try another dealer?
Welcome Charlie,
It pays to put in your location (at least country) and Model/year when setting up your account profile, especially if you want help. We are a world wide forum and vehicles vary by location and factory of manufacture.  :cool:
Brake light switch issue can be random so brake light coming on doesn't always mean it is ok. It maybe something else but that is the easiest and most likely cause.
Offline charlie8
Sorry yes good point.
This is 2012 1.6CDRi, and UK version ( so no Aussie recall ), FSH so Hyundai should have done everything when serviced. Annoyingly this happened 6 weeks after warranty expired :(
Ideas about brake switch I thought too, however brake lights are ok and hence circuit should be good ? And that should trigger the light under 50 mpg, from what I have read ..... I think
  • i30
Sorry the model transitioned from series 1 (FD) to series 2 (GD) in 2012, so is it a series one or a series 2. Our Logo has a series 1 on the left and series 2 on the right. Yes the 50km thing is a bit odd. hopefully someone will have a brainwave.  :undecided:
I had to do some homework. Sorry it was ESP off light was the brake switch related issue I had. So ESC, I don't know but there would be a few sensors tied into that. I would think a fault code scan whilst the error is displayed would be a start point.
Interstingly we had a voluntary recall on the ESC module too over here end of 2010 to 2012 FD series.
Offline charlie8
Thanks so far - its the GD
I tried the ECU reset via the battery disconnect for 30 mins - hit 50 mph and on it comes again :( Checked it does it in a different gear too
The brake lights seem fine, even just a slight touch sets them good
There is an obvious link somewhere, but just need someone to know the algorithm at 50 mph that throws it.
I still refuse to pay £96 for a simple code read - makes me want to steer clear of Hyundai for good, but does not seem to be Hyundai specialists out there that can read the ABS or DCS modules
  • i30
If paying the £96 and problem i/d have they indicated the money will be offset towards any remedial action?
I'll tag two of our other technical advisors and see if they have any ideas.. just don't mention exhaust wrap.... @nzenigma and @cruiserfied
ns
Offline charlie8
For a minute I thought I had it via the clutch switch, that would explain a lot if it did not think it ever got out of neutral as an on/off switch. By car ONLY starts with clutch down - so I guess its not that
  • i30
Have you tried changing fuse to see if that cures it?
Offline sundiz
      Helsinki
Not sure if Hyundai might have same issues, but at one point Mercedes had similar issues. It was caused by uneven tyre wear. Front and rear tyres did not have same radius and the "speed" difference became too big in higher speeds. Also happened with different brand (same size)tyres on front and rear axel.  And especially if front and rear had different size tyres...
  • i30 cw 1.6crdi -08
ns
Cheap option. How many ply would you recommend? Personally I prefer the printed version.
Hi Charlie.
This sounds like a programme glitch. The 50 mph occurrence seems too precise to be a mechanical or intermittent device problem. Same verdict when you try to force the ESC to operate. :'(
The dealer who simply wants to read codes is a rip off merchant and hasn't, or isn't capable of, getting his head around this.
I would try to find another repairer. It will require on-road testing.
Have you tried driving after  turning off ESC at startup? If you have sport mode, you need to press that button and the ESC button simultaneously. Could be a way of noting a problem or even induce a reset.
Sorry cant be of more help. Lets see if @cruiserfied is about. He's our genius.
ns
Good on ya Dazz    :(   Now emerges all our resident shite stirrers .  :rolleyes:
 :rofl:
Offline charlie8
Yes, tried ESP off when started - 50mph and the ESP warning light comes on
I note there is a clutch down switch that seems to work, but what tells the man gearbox that it is in neutral - presume it cannot just be the its not fully engaged ?
The ISG used to always stop as soon as go into neutral - so is there a switch some else to tell when its in neutral rather that just no signal from a fully down clutch pedal ?
  • i30
There may ??? be a link to the ISG, we don't have it in Australian i30s. Possibly because it seems to be problematic. :link: ISG not working
Q. Is the ESC problem Rpm. related?
 In other words, does the light come on at 50mph in both 5th and 6th gear? Assuming its a 6 speed box.
May be contradicted by a Brit owner, but clutch down switch is normally unrelated to neutral, eg. you can start in any gear.
The box neutral switch is midway down the front of the box, it looks like an oil pressure switch.
Neutral Gear Switch senses the driver′s intension to shift gear.
When vehicle starts to move after standing for a while and vehicle speed does not reach 2Km/h, fuel quantity mapping value at neutral gear is adopted to vehicle.
Moreover, this phenomenon is more serious when vehicle requires high power generation such as the situation when vehicle is on the slope.
To cope with this problem, neutral gear switch which senses driver′s intension of starting to move is applied. And fuel injection quantity mapping value suitable for 1st gear is adopted immediately.
« Last Edit: September 17, 2017, 22:42:22 by nzenigma »
Offline charlie8
Interesting and thanks you
Yes ESC comes on in different gears, I tried this already to remove the link to RPM, it does seem to be all speed
This is the bit I don't get, if the ISG and cruise control might be explained by a bad neutral switch and info about the state of the transmission, whats the link to the ESC and 50 mph ?
  • i30
I'm bouncing thoughts across the globe so :confused: here goes again;
I think you only have one component / programme causing the drama.
the 'ESC off' trigger must originate from the gearbox output sensor ( its a hall effect sensor on the gearbox above the driveshafts.) May be interesting to disconnect it. They are usually trouble free, but could be doing its own thing, or the ECU is using the signal to do same.
Vehicle Speed Sensor (VSS) is hall sensor type and senses the rotating speed of differential gear mounted on transaxle.
Comparing engine speed with vehicle speed calculated based on vehicle speed sensor signal, ECM recognizes engaged gear.
And based on the information about engaged gear, ECM performs optimum fuel injection quantity correction.
VSS signal is also used in speed meter of cluster, aircon control module, BCM, etc.
The FD model brake switches have 2 circuits, one for stop lights, the other to turn off cruise control. When faulty, they will also cause the ESP/ESC light to turn on. Restart the car and ESP light will be off. Similar to your problem. Keep digging :goodjob2:
« Last Edit: September 18, 2017, 22:31:35 by nzenigma »
Charlie,  This constant 50mph has me thinking that the problem lies in the area where you set a speed. The cruise control.
Have a think around that area. Could be a faulty module or as simple as a sticky button.
cheers
Nice lateral thinking Gary. Thanks for your input!  :goodjob:
I wasn't wrapped in that other thread, but this is a good one.  :snigger:
Offline charlie8
Thanks everyone, it feels like we are getting warmer
The job of the VSS does seem to be a common denominator based of how you describe. I had naively assumed that if my speedo was working  then it must be OK, without knowing the detail of what else it does, like which gear.
Also, I recall when I got Hyundai to change my front brakes ( a few weeks before this happened ) they talked about a free check they needed to do around the a drive shaft ( I presume some kind of silent safety check ). They said on pick up there was nothing to do so I  did not push for details, but if someone was sniffing around there .....
Can you help me ID where that sensor is, I had a quick sniff around for the neutral switch last night in the bay based on what you said, but found it hard to locate and limited pics on-line. Do you have pics handy about the VSS location, so I don't mess with the wrong plug  ?
I guess the sensor cannot be totally out as presume this would reg as a perm fault even at low speed ?
  • i30
OK Have a box out at the moment. Got a few things on early tday, but back this pm. G
Sorry just remembered its a GD auto and my manual boxes are FD.
This is neutral switch
and speed sensor
Offline charlie8
Thanks alot
Crikey I can just about see a ARB and steering rack to figure out the intermidiate connector location - what is that BTW ?
The VSS looks in 2 parts - the mechanical and electrical - I guess the top bit that could be at fault with mine, else the speedo would definitely not work
  • i30
The top Hall effect unit used to be a solid speedo cable back in the good old days.
Don't ignore the possible 50mph Cruise setting. If CC is optional in the British GDs, I suspect there will be a  module that can be disconnected.
Just checked, switches go directly to the ECU, however , several listed CC faults are due to a faulty speed sensor.
« Last Edit: September 20, 2017, 20:46:41 by nzenigma »
Offline charlie8
You are most helpful -  a credit to the forum - i will explore at the weekend armed with this knowledge
A virtual rounds on me :)
  • i30
He can be a "stirrer" too.. But it's great to see good help being given and acknowledged  :goodjob:
Have been following this post , sometimes re-reading as well and thinking , canal, far-canal.
Looked at a FD yesterday as replacement for yougest's dead 323.
 ESP OFF was illuminated,  pressed the switch a couple of times, still illuminated.
Dealer said "ohh, we'll fix that easy, but guys like us don't need that to drive",   :eek:
Car supposedly had a 100 point safety check.
Walked away rememberingthis post.
