Swapping out a i30 Navigation unit for GD-03 unit
GreyBanna · 26 · 17803
Offline GreyBanna
Hi all,
I havent been able to find another post like this one so I decided to share my experience so far.
I bought a 2015 i30 SR in September of 2015. A few months later I came across news of the update being offered to eligible i30 owners with the GD-03 unit that would allow them to use Apple CarPlay and Android Auto. I immediately sent Hyundai an email to see whether my Navigation model was included in this update.....It was not.
At this point the seed had been planted. I came across this forum and soon after bought a GD-03 unit. My intention was to swap out my Navigation unit for the GD-03 unit. The biggest reason was because i wanted CarPlay so that my phone would be better integrated into the car. Secondly, I don't like having a GPS unit with maps that are 6 months to a year out of date CONSTANTLY and then require updates (which would cost me money after 3 years, and thats not including the $$$ subscription required for the traffic updates via SUNA) which again are out of date from the time they are uploaded to the unit.
So here is my install guide / journey.
For those of you that are interested, here is the link to the Service Manual for the Hyundai i30 Navigation unit (Model No:LAN1050EHGD): http://www.basexml.com/xdrp/xmldoc/images/lan1050ehgd.pdf
I will not be showing how to remove the trim etc as this has been discussed before. I will be showing the steps necessary to install the GD-03 into the place of the Navigation Unit.
This is an excellent post to removing the trim and unit: :link: HOW TO: UPGRADE YOUR GD-01/GD-02 TO A GD-03 HEAD UNIT STEP-BY-STEP GUIDE
  • i30 SR 2015
Offline GreyBanna
This is the back of the navigation unit. Starting from the bottom left of the unit; note the square aerial connector (the gd-03 unit uses a round connector for the aerial)- to use the existing connector you will need a farka to round adaptor such as this: https://www.google.com.au/search?ei=JQYFWtDyG8Tc0ASt06KgDg&q=farka+to+round+aerial+adaptor&oq=farka+to+round+aerial+adaptor&gs_l=psy-ab.3...3481.4743.0.4949.2.2.0.0.0.0.423.423.4-1.1.0....0...1.1.64.psy-ab..1.0.0....0.hwXs8mOOnm8
Next, note the white rectangular plug directly to the right of the aerial plug. This is the reverse camera connector which contains 4 wires as follows. Pay attention to the information on the right side of the image.
.  You will need the following pin's;
Pin 12- CAMERA_CVBS - (CVBS stands for Composite Video Blanking Sync) This is the 'image' from the reverse camera.
Pin 10- CAMERA_B+   - This is the positive wire to supply power to the camera.
Pin24- CAMERA_VGND - this is the ground for the video signal (pin 12)
Pin 22- CAMERA_PGND - This is the ground for the pin 10.
Pin 12 and Pin 24 are related. Pin 12 is the video image being sent to the head unit, Pin 24 is the ground wire for the video image/wire.
Pin 10 and Pin 22 are related. Pin 10 is the positive from the car battery and Pin 22 is the ground for this.
  • i30 SR 2015
Offline GreyBanna
The following is the female connector, the connector on the backside of both the Navigation unit and the GD-03 unit.
The following image is the pinout of the Navigation unit.
The following is the pinout of the GD-03 Unit.
I have depinned (by shoving s small pin into the connector to unclip the wire's) and repinned as follows;
Pin 12- Moved from original connector to A15
Pin 10- Moved from original connector to A6
Pin 22- Moved from original connector to A5
Pin 24- Moved from original connector to A14
Focusing now on the Navigation unit pinout, i moved the reverse pin (Pin A7; Reverse_Gear) to the GD-03 pin (A9; Reverse).
Here is the issue i now face. When i put the car into reverse i can hear the reverse camera raise the Hyundai logo on the back of the boot lid BUT the GD-03 unit will not activate reverse mode to display the image from the reverse camera. THe GD-03 unit remains on whatever screen / display it is currently displaying.
I have noted that the reverse pin (A9) on the GD-03 units i have seen in this forum have a wire color that is yellow. The reverse pin (A7) on the Navigation unit is black with a brown stripe on it.
Something tells me that the GD-03 unit is not receiving the correct voltage to switch over to the reverse mode and display the reverse camera image.
Can anybody confirm this for me?
  • i30 SR 2015
Offline GreyBanna
The next problem was again to do with the different pinouts of the Navigation unit and the GD-03 unit.
The sound that was coming out of the speakers when I plugged in the GD-03 unit was 'wrong'. This was due to the difference in wiring.
I solved this issue by depinning (shove pin into connector and removing cable) and then changing location of the wire to match that of the GD-03 unit.
Focusing on ONLY Connector A;
(it helps to remove all pins first to make this step less confusing - note the color of each pin A1-4 and A10-13 - DO NOT confuse colors)
Pin A1 from Navigation moved to A2
Pin A2 from Navigation moved to A12
Pin A3 - NO CHANGE IN LOCATION
Pin A4 from Navigation moved to A11
Pin A10 from Navigation moved to A4
Pin A11 from Navigation moved to A13
Pin A12 from Navigation moved to A1
Pin A13 from Navigation moved to A10
« Last Edit: November 10, 2017, 03:10:03 by GreyBanna »
  • i30 SR 2015
Offline GreyBanna
So now the sound is working correctly.
The next step was to relocate the wires for the steering wheel controls (volume + -, Mute, Mode, Answer call & Hangup call).
Hint: Even with the pins swapped over these controls do not work. I can only assume that the signals (or drops in voltage or change in resistance)- whatever the ECU/BCU/Head unit uses to identify what button is being pressed is different to that has been programmed into the GD-03 Unit. That is to say, the steering wheel buttons designed to work with the navigation unit are sending the wrong signal to the GD-03 unit and as a result the GD-03 unit does not respond to the button presses.
Pin B5 (Steer_Key) and Pin17 (Key_Gnd) on navigation unit were swapped as follows;
Pin B5 (Steer_Key) changed to B4.
Pin17 (Key_Gnd) - NO CHANGE IN PIN LOCATION
  • i30 SR 2015
Offline GreyBanna
There is an issue of fitment when replacing the Navigation unit with the GD-03 unit.
Note the façade gaps between the GD-03 unit and the aircon control unit.
I think this can be solved quite easily by removing the façade from the aircon control unit using the clips (connecting facade to aircon control unit) on all 4 sides;
This is the result;
My thought process is; source façade from aircon control unit (or entire unit) from i30 with GD-03 unit installed. Swap over façade--> problem solved. From the pics it appears that this should be possible (See pic below)
  • i30 SR 2015
Offline corza_21
      Brisbane, Australia
Fantastic write up, please keep us updated on how it goes. Thanks for being the guinea pig!
Sent from my SM-G935F using Tapatalk
  • 2012 GD Premium CRDI, Auto, White
Offline GreyBanna
No problem!
Does anybody know what voltage the GD-03 unit uses to activate reverse mode on the A9(reverse) pin? Or if it uses something else aside from a voltage, like a code or similar?
The reverse wire from the navigation unit does not activate reverse mode on the GD-03 and I’m stumped at the moment. I cannot detect any voltage being fed through the when I put the car into reverse.
My only other option may be to feed a 12v voltage from the 12v outlet located beneath the unit in order to activate reverse mode. My only worry is that I know the reverse camera runs on 6v and not 12v. I don’t want to fry anything.
Thanks!
  • i30 SR 2015
Hi GB,
looking at our GD surround , it definitely has higher wings on each side 👍👍👍
I'm wondering if your aircon/fan will even work if you change it to the manual type :undecided: in your situation I probably would have opted for a third party (JVC etc) head unit and matching fascia from Aerpro :link: Facia Kits | Aerpro
After re-reading I see you're just wanting to change the aircon fascia, hopefully it'll match :fingers:
« Last Edit: November 11, 2017, 05:34:45 by CraigB »
Offline GreyBanna
Here is an update to this project;
So I bought a wire harness (female to male) which would allow me to plug it into the existing factory wiring loom.
The advantage of this harness is that I can cut and splice wires without affecting the factory wiring as well as allowing me to put the Sat Nav head unit back without any modification or damage.
It has worked really well and all features are working correctly, including the reverse camera, steering wheel controls etc...
To allow for the modification of the reverse camera I simply bought a female 24 pin connector as seen below
and added a RCA video output as well as an RCA video input and wired them up with the power and the reverse input / detect wire.
I bought an adaptor for the aerial from super cheap auto and that solved the radio issue.
At the moment I'm going to pick up a façade for the air con unit which will fix the gap between the GD-03 unit and the aircon unit.
Very happy with the result and it looks factory which was the most important thing to me. And even more important is the ability to switch back to the factory sat nav unit should Hyundai crack a hissy fit over my modification.
  • i30 SR 2015
Offline corza_21
      Brisbane, Australia
Awesome work, can't wait to see the finished product!
Thanks @GreyBanna for that tip and photos.  :goodjob2: :goodjob:
Offline fugoide
    • es Spain
First of all, Hi all! I am new here, with an i30 series II (2016) in Spain!.
Secondly, thank you very much for this post @GreyBanna. I think I am going to be the guinea pig here in Spain!
First of all, here in Spain, the first i30 with the android / apple carplay head set system is the new model of (2017). Opposite to Australia, all cars here until last year they came with the old GD-02 or the navigator version (my case and a complete shit). This is why I saw this post and I decided to purchase a GD-03 in Australia and import it to Spain (kind of odyssey, but I think I will manage to do it).  I have some questions regarding this DIY task:
1) here in Spain, our steering wheel is in the left hand side. it would be any problem in getting the GD-03 from Australia? I mean, any problem connections with the steering wheel controls?
2) I use a lot the FM radio integrated in my navigator head set, if I manage to install the GD-03 from Australia version, any problem regarding frequencies of FM radio here in Spain? Are they different?
3) As you @GreyBanna, I have the navigation unit, with the dual air condition unit (with the display) as you have. My colleague here have the same condition unit but no navigation unit, just the basic one, in which the plastic shell is a litlle bit smaller in shape and then, completely compatible with the GD-03. I will try to pic a photo of this configuration, but I think it is only a change in the plastic shell of the air condition unit with a compatible one.  UPDATED: I attached a photo, I think this is the plastic frame that we need to get for our change from navigation unit to GD-03.
4) Will I have problems with the GD-03 official updates? Since I will not have to access to a authorised dealer for the upgrades, it would be possible for me to get and install all updates from internet?
As all people here, waiting for news in your progress.
Thank you all!
« Last Edit: December 19, 2017, 00:17:32 by fugoide »
  • hyundai i30 2016
Hola, paisano. De que parte de España?
Since we drive on the other side, the console is angled towards the driver and this means that you have to source the unit to suit something like an American Elantra.
I think FM frequency ranges in Australia y España are the same, 88-108 MHz.
As for updates, I believe some members have been able to make them available here by link.
Mucha suerte! :victory:
nsns
Offline fugoide
    • es Spain
Wey! Another Spaniard! Good to hear that! Soy Andalúz.
Thank you very much for your replies. I have verify the console angle in my current model and I cannot appreciate any angle variation. Same view from pilot and copilot. I do not know if there is any difference internally. The problem with Elantra is that case and plastic frame are different from i30 and I think it will be more difficult to fit it.
In addition I think I managed to get a unit in Australia easily.
  • hyundai i30 2016
Offline GreyBanna
Hi all,
Sorry about not posting for a while. I finished university and got a job, which is now consuming all of my time.
I’ve decided to replace the stock navigation unit. There was nothing wrong with the GD-03 except for the amplifier within the unit.
The sound output (I couldn’t find a wattage output for both units) from the Navigation model compared to the GD-03 model was quite obvious.
There is not enough power being output from the GD-03 to power the 6 speakers in my car to the same level as the Navigation unit.
There was a large amount of bass missing (couldn’t not be provided no matter how I altered the EQ or loudness or either combination).
It would be a different story if you had a subwoofer as the subwoofer would be able to provide the missing low end.
And secondly, to get the reverse camera to work in my car required running a wire from the reverse light, through the plastic trim, along the headliner and through the rubber boot, into the boot, and then to the + of the reverse light. Unfortunately I don’t have time for this anymore.
Other than that the GD-03 worked great; but could not provide the sound that I had become accustomed to (And I like my sound).
  • i30 SR 2015
Good to hear from you. Well done on the stereo and job front! :goodjob:
Hi all,
The GD03 head units put out 50w (17rms) per channel, if not using high efficiency speakers like I did with the Morels you'll need an amp.
I havent decided on whether I need a sub at this stage, the Morels absolutely pump :D
Offline hasbags
    • Australia
I'm keen to try this on my partners 2012 i30 with nav, but swapping it for a GD-03 unit with built in nav.
I'm hoping that might cause less issues than the non-nav unit.
Do you know what the GD-02 head units put out? If the GD-03 unit doesn't output enough it mightn't be worth it.
  • 2012 i30
Both 02 and 03 non navigation models are the same power, Not sure if sat nav units are the same :undecided: you could call Alberts or similar and ask as they would/should know.
« Last Edit: April 16, 2018, 04:18:55 by CraigB »
Offline aanastasiou4
    • cy Cyprus
Does anyone know the part number for the aux wire?
  • Hyundai i30 2012
guest9517
The original reverse motorized camera i put on mine (On Android unit) is for 12V, i dont know if yours is 6V due to being Korean built & mine Czech?
    • cy Cyprus
I retrofitted my oem camera on the gd-02 and I am now waiting for my gd-03 unit to arrive. Mine is 12v
  • Hyundai i30 2012
Offline fugoide
    • es Spain
I got a GD-03 unit. How do I know if my unit comes with built in Nav? I thought all GD-03 were made wihout nav function (since they use apple or android navigartors). however my GD-03 presents same connectors as Greybanna unit, then I think it comes without the Nav. Now trying to get the cable harness before starting all tedious process...
  • hyundai i30 2016
Non navigation units have a different facsia to those with navigation, I’d expect the sat nav capable unit to also be mentioned on the rear sticker.
